Rear Ballast Pump Upgrade/Revision
  • jroyal
    • Aug 2003
    • 342
    • A, A
    • 2008 210 Black/White 2001 Super Air Black/White
    I have a 2001 SAN that has the factory tanks in the rear. I had previously replaced the the stock ones (750 GPH) with 1200 GPH ones. Now, I want to replace all the ballast hoses with newer hoses (since the older, plastic ones have been known to have issues.) Since I will be replacing all the hoses, I wanted to change the routing where the water discharged from the side of the boat, so I can empty while underway.
    Attached is a proposed diagram. I am looking for comments to such a setup. I already own two of the Rule 1200 gph aerator pumps, so I would like to use those. I want to use one pump to fill and one pump to empty. Since factory tanks only have one inlet (I believe,) I am not sure I have the routing correct. Any suggestions are welcomed. Thanks.
    Rear Ballast.pdf
    2008 Team Edition 210 - Black
    2001 Super Air Nautique *Sold*
