I have a set of flight clips that mount to the tube of the tower but they are for a 2 1/2" tube and my tower tube is 2" has anyone found or mad a spacer to in the clamp so these will work on my tower?
Clamps
I went through the same process and I feel your pain. I bought some Fundemental Design Racks and adapted Monster Tower Spacers to fit my tower. I think the adapters kits were $25.00 for each side. They have been mounted for 2 Years and the spacers work great. I think your tower is 1 7/8". I know that is the size of the tower on my is 2005 Super Air TE.
I was thinking about putting the OEM Spinners on my tower as well and when I was doing my research I emailed the OEM supplier (I think Skylon) and they said them might be able to machine an adapter sleeve/spacer for a nominal charge. Just an option.
In any event a good file and patience will make your project go smooth.
You can look at www.bulletlines.com, someone guided me there today for the very same thing. Look under other accessories. Very inexpensive too. You probably have 1 7/8".
Originally posted by shag View PostYou can look at www.bulletlines.com, someone guided me there today for the very same thing. Look under other accessories. Very inexpensive too. You probably have 1 7/8".
Thank you this was exactly what I needed2003 226 LE
