What is the purpose of the plastic covers that prevent access to the rear lifting/tiedown rings from under the swim platform? Can these covers be removed without causing any problems? I guess they must be there to either keep exhaust fumes from coming through that opening or to keep water from spraying through the opening on takeoff. I can't think of any other reason for them to be there. I'd like to use the rings as tiedowns when the boat is on the trailer.
What is the purpose of these?
RE: What is the purpose of these?
Not sure but it may be to keep a dummy from hooking something to be towed to them. Just a guess.Life is Short, Live it!
http://www.teamcarolina.us/index.htm
I am not sure what they are for but replacement cost on them is $40 dollars each. All summer they kept getting ripped off the back of the boat. I finally had to mount them with rubber spacers so they would not flex as much and break off during hole shots and hard turns. We rode for awhile with them off and never had a problem with water shooting up through the space. I put them back on and still have no idea what they do.
It's for preventing exhaust fumes from coming up through the swim platform.
Rumor has it that years ago CC used to have holes in their swim platforms, kinda like the MC's, and somebody apparently died and CC was subsequently sued. Since then they've built solid platforms to prevent such occurences.
Chris
Cool. Thanks for the info, everyone. I'm sure that with the passenger area of the Super Air being so far from the rear of the boat, I'll probably live if I remove them. I will feel much more comfortable pulling the boat with the rear secured to the trailer.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
There will be holes exposed from where you remove the screws. You are alot better off to get a transom strap to hold the boat down instead. Yes they are designed to keep the fumes from coming up toward riders and passengers.
I think they started this on the 1990. Mine goes as far as having a plexiglass covered bottom of the platform and weatherstripping where the platform meets the boat for a good seal. So, it looks like the platform has slats in it but really it's the black plexi underneath. I can't imagine how much time it took to manufacture the platform but there is more engineering and craftsmanship in my platform than in most parts of other manufacturer's boats.
Re: RE: What is the purpose of these?
Originally posted by skinautiqueThere will be holes exposed from where you remove the screws. You are alot better off to get a transom strap to hold the boat down instead. Yes they are designed to keep the fumes from coming up toward riders and passengers.
I really don't want to use a transom strap because of the possibility of the strap flapping around and scratching my black gelcoat. I also wouldn't be able to tow with my cover on with a transom strap.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
RE: Re: RE: What is the purpose of these?
You can tow with the cover on. I have done it plenty of times. The trick to protecting the gelcoat is to lay a towel down between the deck and the strap itself. If you wanted to, you could remove the cups all together and put the screws back in. Just put 3M 4200 on the screws as a sealer.
I have always heard they were to keep exhaust fumes down too!2008 Super Air 210 Team
2004 AIR 206 Team
1997 Ski Nautique 196
1993 Ski Nautique SNOB
We have now had 4 consectutive super airs and for some reason both covers have fallen off the new boat and its only done 25 hours. Never lost any off the other boats, the sika flex must have been a bad batch. Anyway it exposes the tie down hooks which is better for tying down the boat.
