SANTE 230 w/ZR6 Range?
  • newNautique
    • Jul 2010
    • 23
    What's an estimated mile range for a new model SANTE 230 with the ZR6? Also curious about GPH estimates? Much appreciated!!
  • Nautiqueman
    • Mar 2004
    • 487
    • Birmingham, AL
    your guage should give you the hours it will run on the fuel in the tank, right?
    • gride300
      • Apr 2008
      • 1356
      • mobile, al
      yes the guage does that, but i would not count on it for anything. it changes so much it's nearly impossible to keep track.
      • BKinSoCal
        • Sep 2008
        • 507
        • Prescott, AZ
        I have the same question. This year I went from a 210 to a 230 and I've been having a difficult time getting an idea of how long a tank will last. I realize there are variables that change this, but in general, I would like to know.
        I agree that the Hours Left gauge is not accurate. I know mine can't be because my gas gauge isn't accurate. I can go from showing 3/4 of a tank at the beginning of a ride to a 1/4 of a tank right after and that ride lasted maybe 15 minutes. Next thing you know, it's back to 3/4 of a tank. My 210 gas gauge was significantly more accurate than my 230.
        There was even a time I went from 1/3 of a tank to empty and the Hours Left gauge read 0...as I drove down river. Needless to say I was nervous, but fortunately I was pulling out for the day.
        BKinSoCal - Brian
        '08 SANTE 230 - Current
        '05 SANTE - Sold '10
        '04 216 TE - Sold in '05
        • AirTool
          • 4049
          • Katy, Texas
          I know this is not the exact answer you are looking for.....but,
          I keep a log of my gas and hours. Over the last 85 hours, my 2006 206 w/330 has averaged 3.06 gallons per hour.
          The average use is wake boarding, knee boarding, some 30 mph footing....and ..... of course.....
          some tooobing.
          There is no "cruising" because its on a ski lake and there is no where to cruise to.
          • johnboyy7
            • Oct 2009
            • 409
            • houston
            I mainly monitor how long I've been out to how much I takes to fill it back up. Ex. 4hrs usually equals about 20 gallons for me. So when I get close to 8hrs I know we are pretty low.
            04 SANTE 210
            89 SPORT
            • shag
              • 2217
              The 230 at the Nationals went through a full tank in about 4-5 hours (99% down to 1% on the new linc) And BTW, it actually starts to run out of fuel at 1% - so that gauge is pretty accurate. This is a boat that had the new bigger belly ballast, sacs on either side of the motor, a sac in the front, and the usual compliment of people for judging/photos. So, lots of stops and starts in a heavily weighted boat, and somewhere around 4500 ft elevation.
              Hope that helps.
              Mike
              • AirTool
                • 4049
                • Katy, Texas
                Originally posted by shag View Post
                The 230 at the Nationals went through a full tank in about 4-5 hours .....
                Mike
                I'm curious. How big is the tank?
                • TRO
                  • Mar 2009
                  • 410
                  • Houston, TX
                  i think my '08 230 has a 52 gallon tank.
                  • shag
                    • 2217
                    pretty sure it is about 50 gallons
                    • johnboyy7
                      • Oct 2009
                      • 409
                      • houston
                      Wow. That's a lot if fuel usage.
                      04 SANTE 210
                      89 SPORT
                      • newNautique
                        • Jul 2010
                        • 23
                        Thanks! Figure a minimum of 4-5 hours then per tank. Too bad they can't squeeze in a larger tank capable of holding a few more gallons.
                        • shag
                          • 2217
                          remember, that is pro tour use - boat running non-stop, lots of falls, very heavily weighted....
                          I wouldn't want to pay anymore to fill up that bigger tank - but can understand the want.
                          • boatbuddy
                            • May 2007
                            • 109
                            When the 230 LINC guage reads 0% it means 0%
                            Our previous 211 boat had a warning beep which was annoying but in hindsight quite useful. We would normally pull into the marina with the low fuel beep cherping....
                            Shortly after getting the 230, the guage went to 0% before we noticed and then we ran out .... we did a little paddling then a short tow to the dock
                            We put 2 gallons in and the reading was between 28% and 32% so the LINC guage is not accurate
                            I would think the LINC system would have a warning system but have not investigated thoroughly yet... anyone know if it does
                            Can you change the font size on the LINC system?
                            • newNautique
                              • Jul 2010
                              • 23
                              There is a flip side to my wish...
