Hola, Ladies and gents i could use a hand... I have a 08' 230 SANTE and i have recently replaced the altenator... no big deal? Well the very next trip i was out on the water and as the day sky married with the evening sky i headed in. On my journey in i ran the boat at about 4800 rpm for maybe 5 min... but steady. Outa nowhere i got a warning light and alarm and a message that read "power reduction seed dealer" i immediatley shut down the motor and checked my strainer... didnt seem to be swirling as it shoulda... so i cleaned it out and it seemed better, temo immedietley went down twenty degrees. Now the issue is now everytime i go from neutral to f/r over say 1500 rpm the light comes on... no alarm but i have to put the throttle all the way forward or all the way back for any action... checked oil, level and cleanliness is ok. Any clues?
Tags: None
Pressure Sensor
Not sure about the power reduction mode - but if you are getting the light now you could have a bad Oil pressure sensor2006 SANTE 210 (Pending Sale)
2005 206 TE (Previous)
3 main reasons for light
The 3 main reasons to get the light are 1. Low oil pressure or bad sensor 2. Overtemp or bad temp sensor or bad knock sensor. I'd start with the oil pressure switch first. Its readily accessible and inexpensive Good LuckNautiqueless in San Diego
I had similar issues with mine and it turned out to be the crankshaft position sensor. They have also had problems with throttle position sensors.00 SAN 210 (previous boat)
07 236 te sold
Thanks for the feedback so far, could you be so kinda to mabe take/find a pic of the oil pressure switch? or explain its location?
... thanks in advance!
Originally posted by imkitbishes View PostThanks for the feedback so far, could you be so kinda to mabe take/find a pic of the oil pressure switch? or explain its location?
...man, not to beat a dead horse, but i have read through this manual http://www.pcmengines.com/pdfs/manua...343_manual.pdf and it says that it covers the 6L but im not finding any info on an oil preasure switch???
to your credit i searched the 07 parts manual(08's aren't available), and the 08 manual on here and did not find it. this is what one from an older engine looks like.
http://www.skidim.com/prodinfo.asp?number=R020015A
