Does anyone run their engine briefly after they've pulled it out of the water?
  • uwhusky
    • Aug 2006
    • 320
    • Salt Lake City
    • 2015 SANTE 210 w/PCM 450hp engine
    I went on a trip recently and noticed my brother-in-law would quickly start up his jet skis after he pulled them out of the water. He helped me pull my SANTE220 out of the water and after we were done wiping it down, etc. he asked my if I started the engine up real quick to help get the water out of it. I said no and I think it seems pretty dangerous in terms of potentials for screwing up your engine.
    Does anyone do that?
  • NautiqueJeff
    A d m i n i s t r a t o r
    • Mar 2002
    • 17179
    • Lake Norman
    • Mooresville, NC
    Not me...
    • teamseal
      • Dec 2006
      • 416
      • Panama city, Florida.
      • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
      Their is no need to start the engine once you pulled it from the water, however if you run in salt water you should flush and run the motor thru a fresh water flush system. Or not Their are a lot of us that can use the work this winter!!
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        Most of the water drains out of the engine I believe, except for some in the raw water pump. I wouldnt want that to drain completely anyway, because it takes a moment for the water to enter that area once the boat is restarted (in the water on the next trip), and I would want that time frame to be as short as possible (not sure if that made any sense)
        Eric, Phoenix AZ
        G23 550 hp (finally here)
        2002 Super Air
        • NautiDave07
          • Mar 2008
          • 333
          • Louisville KY
          • 00 SAN210 07 236 TE
          Starting the engine after pulling out of the water in a boat is a bad idea. Jet skis call for it in the manual as it clears water out of exhaust and jet pump. Don't do it to your boat.
          00 SAN 210 (previous boat)
          07 236 te sold
          • kevfran99
            • Sep 2008
            • 335
            • ATL
            • 08 210 SAN Team
            +1
            '08 SAN 210 Team Black w/Patriot red top stripe-Tow Biminis over the tower-4 under water transom lights-hot/cold shower-crest carpet-full throttle steering wheel-extra 6 channel JL amp-Pro 80's-WS420-fiberglass sub enclosure-led'd vents-Chromax Letters-and Tinted windshield for now......
            Tow Vehicle--05 GMC 2500 Crew Cab Short Bed 6.6L Duramax/Allison with a few mods
            -GO DAWGS!-
            • migs
              • Aug 2008
              • 707
              • San Mateo, CA
              • SAN 210 TE
              Never-never-never
              ever
              Migs
              G21 - En route
              SAN 210 TE (Finally)
              06 Sky Supreme V220(previous)
              05 Sanger V210(previous)
              01 MC X1(previous)
              99 Air Warrior(previous)
              • obd666
                • Feb 2010
                • 793
                • Bostian Heights, NC
                • 03 SANTE
                negative
                2003 SANTE - "OG 210"
                • DealsGapCobra
                  • May 2010
                  • 375
                  • Knoxville, TN
                  • Ski Nautique 200
                  +2
                  I always wondered why the "ski" guys did this and thought is was pretty annoying. I came across and older WaveRunner and sure enough, the manual calls for it. I guess I am annoying once in a while.
                  I never run the boat like this.
                    DO NOT RUN YOUR BOAT WITHOUT SUPPLYING WATER TO THE RAW WATER PUMP!
                    It has to have a constant supply of water to not destroy the impeller.
                    • BP22
                      • Jan 2007
                      • 248
                      • Covina, CA
                      • 2006 Super Air Nautique 210
                      Never.
                      Brandon
                      2006 SAN 210
                      • uwhusky
                        • Aug 2006
                        • 320
                        • Salt Lake City
                        Alright, it sounds like we're all in agreement. I'll tell my bro-in-law to let it go and not to do it to his Tige, which I'm pretty sure he might do.
                        • Goad2001
                          • Aug 2010
                          • 4
                          • 2001 Pro Air Nautique
                          Will definitely shorten life of / damage your impeller......
                          • Nautiqueman
                            • Mar 2004
                            • 487
                            • Birmingham, AL
                            Burn up one impeller and lodge all the rubber pieces in the water lines into the engine and you won't ever do it again! The impeller gets very hot if it does not have water cooling it!
                              • 2908
                              I don't do it. However impellers are a bit more forgiving than most of you tend to believe, especially if you replace them annually as we should.
                              My boat motor is extremely quiet (Excal in a 211). One time my nephew pulled drove the boat on the trailer, I drove the truck and pulled it up the launch ramp and over to the washdown area. When I jumped out of the truck I heard a motor running faintly and thought who is the goofball that is running his boat out of the water. That goofball was me, because my nephew had forgotten to turn it off! It probably ran for 1-2 minutes and the impeller lasted the rest of the season. When I changed that impeller it didn't even look damaged, I was surprised.
                              Against all recommendations I do bump the motor until it fires everytime before launching. I do it because it's usually my wife and sister in the boat and I don't want them to get stuck in a boat that won't run for any unknown reason. It runs for less than 5 seconds and I have been doing since the boat was new. I doubt it even has time to spin the impeller dry. That said I don't condone the practice for others.
