1999 SAN with Gen 1 Tower
  • ksdaoski27
    • Mar 2010
    • 66
    Hello-
    Tried doing a few searches to get some info, but whats the background on the Gen 1 towers found on 1999 Super Nautiques?
    Looks like it fold back, with the front legs high in the air? Will it fit under a 7' garage door?
    Are there quick release knobs you can add to speed up the process, or facilitate a complete removal?
    Also, if replaced with a Gen 2 tower, do the holes match up?
    Thanks!
  • WakeSlayer
    • Sep 2005
    • 2069
    • Silver Creek, MN
    • 1968 Mustang
    My friend folds his forward. I believe he has a 7ft door, but will confirm.
    Gen2 will not even remotely fit where a Gen1 was or even on it. Totally different.
    the WakeSlayer
    1968 Correct Craft Mustang
    • ksdaoski27
      • Mar 2010
      • 66
      thanks, would be great to understand the height
      • Miljack
        • Dec 2004
        • 1616
        • Charlotte, NC
        • '08 230 TE ZR6
        I originally had the FCT gen.1 on my '99 Pro Air (slightly different version than on the SAN, SAN front "foot (mounted on the deck) is higher), and I had to remove my tower to fit under my garage door. I had removed the rear bolts and folded forward as I remember, and ended up removing the tower completely to get it to fit. My trailer is a single axle, so it may sit higher due to the 15" wheel and tire combo, than a tandem axle w/14" wheel and tires.
        2008 230 TE-ZR6
