Replaceing Zero Off display in SN200
  • actman
    • Dec 2009
    • 166
    • Ontario Canada
    • SN 200 OB many 196's
    Zero off has sent me a new display to replace my faulty one under warranty. Does anyone know how
    the best way to remove the old one is. Its now in the side console. My boat is up north so I don't have it
    here to figure it out. Any help would be great.
    My dealer would do it for free under warranty but its a long drive to them and back so I would rather try myself.
  • ClemsonDave
    • Oct 2004
    • 659
    • Glen Allen, VA
    • Ski Nautique 200
    I have not done it on the 200, but all the others are held on with a U shaped bracket held by 2 small nuts. Once you get those off, you should be able to slide it out and remove the electrical plug.
    Promo Team member
    1999 196
    2010 200 Team 2010 200 Team
    2011 200 Team 2011 200 Team
    2012 200 Team - 2012 200 Team
    2013 200 Team - 2013 200 Team
    2014 200 Team - 2014 200 Team
    2015 200 Team - on the way
    • actman
      • Dec 2009
      • 166
      • Ontario Canada
      yes thanks I was told that by zero off but im not sure how to get in there to do that!
      I will take a look this weekend at it
      • swc5150
        • 2240
        • Eau Claire, WI
        • MasterCraft Prostar
        Don't bother Act. A brand new ZO will be installed in the 2011 they owe at this point! You got the lemon this year:-(
        '08 196LE (previous)
        '07 196LE (previous)
        2 - '06 196SE's (previous)
        • actman
          • Dec 2009
          • 166
          • Ontario Canada
          will have to agree with you!
          • ClemsonDave
            • Oct 2004
            • 659
            • Glen Allen, VA
            • Ski Nautique 200
            Just checked mine. You can reach behind the panels without removing any of them.
            dave
            Promo Team member
            1999 196
            • actman
              • Dec 2009
              • 166
              • Ontario Canada
              dave
              Is it two wing nuts that hold it in place?
              • ClemsonDave
                • Oct 2004
                • 659
                • Glen Allen, VA
                • Ski Nautique 200
                Hex nuts, but they are not that tight. I'll be out there again tomorrow afternoon and will take some sockets to see what size they are. I didn't try, but all the ones I have seen have been able to be removed by hand.
                Promo Team member
                1999 196
                • actman
                  • Dec 2009
                  • 166
                  • Ontario Canada
                  Thanks again Dave
                  It would be nice to have one more thing start to work right in my boat !
                  • ClemsonDave
                    • Oct 2004
                    • 659
                    • Glen Allen, VA
                    • Ski Nautique 200
                    Thanks again Dave
                    Have you talked with anyone at CC about these issues? I think it would be good to keep them involved. This is obviously a rare occurrence and I'm sure they would be interested.
                    Promo Team member
                    1999 196
                    • skiinxs
                      • 374
                      • St. Louis
                      • 2019 Ski Nautique 6.2 arriving soon
                      ZO Head unit swap
                      Two nuts finger tight, you won't need a wrench. It is easier if you are left handed, but even though I am right handed I can have one out in 30 seconds and back in in 5 minutes. (It is a little trickier to get the lock washers on the posts without falling off before you put the nuts back on. Use the wing nuts from the replacement unit, they are easier). Take the nuts off, pull the head unit out the top to remove the wiring harness plug (easier than fighting it from behind), plug the new head unit into the wiring harness from the top, push the new head unit into the hole and get it to the right angle, place the bracket over the studs from behind, put the wing nut and lockwashers on each in one move. Make sure the studs are the right distance apart using the bracket on the replacement unit before putting back in. A flashlight or drop light helps you see the bracket alignment from the rear.
                      Dave
                      16 other Ski Nautiques
                      3 MasterCrafts
                      18 Ski Supreme's
                      1 SlickCraft Squirt Boat
                      • actman
                        • Dec 2009
                        • 166
                        • Ontario Canada
                        Thanks so much for the instructions! I like the sound of an easy job.
                        • actman
                          • Dec 2009
                          • 166
                          • Ontario Canada
                          Yes Dave I have. This week they will get my full attention especially on the transmission matter.
                          I have had alot wrong with this boat and have not mentioned it all. I have owned enough of these boats to know
                          CC is the best product but Quality control is slipping and they need to look into it. I don't want to take over this forum with all my problems but its crazy to have this many. My last 196 a 2003 was awesome, no problems at all that I can remember. So when push comes to shove this upcoming week is on!
                          • ClemsonDave
                            • Oct 2004
                            • 659
                            • Glen Allen, VA
                            • Ski Nautique 200
                            They are wing nuts. I'll post a picture tonight. Easy to reach.
                            Promo Team member
                            1999 196
