2001 Air Nautique Speedos
  • Chasstelli
    • Sep 2010
    • 8
    • Northern California
    • 1972 Ski Nautique 1974 Ski Nautique 1989 Sport Nautique 1990 Ski Nautique 2001 Air Nautique
    I have a 2001 Air Nautique with the digital speedos and tach. I have changed out the speedos 3 times. Two of the times through warranty and one time on my own dime. The third speedo gave out last year and since have been going bye the tach, well up to now anyway. This weekend my tach went out. Any suggestions? Thanks in advance for any response.
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    Go to nautiqueparts.com and order the analog versions. They have a package for the tach and speedo. I am not sure about the 2001 versions, but I know the 02s were known to crap out and required replacement. Use the promo code from this site and I think you get 10% off
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    • 74green
      • Nov 2009
      • 281
      • Canyon Lake, Texas
      • 2001 Air Nautique
      +1 Faria Conversion Kit from http://www.nautiqueparts.com/gauges_tach.aspx
      Current: 2001 Air Nautique GT-40
      • Chasstelli
        • Sep 2010
        • 8
        ERS 906 and 74 Green
        Thanks to both of you for pointing me in the right direction. Looks like they have replacements for both the tack and speedo.
        Are these plug and play replacements or will there be a reinstallation process?
        Thanks again
        • ers906
          • Feb 2010
          • 921
          • Phoenix AZ
          I should be receiving mine on tuesday, and I can let you know
          Eric, Phoenix AZ
          2002 Super Air
          • 74green
            • Nov 2009
            • 281
            • 2001 Air Nautique
            The Tach is plug and play (almost). The new speedo does require a 2 inch hole thru the hull for the new sending unit /paddle wheel unless you have PP. If you have PP I believe your kit ties into PP.
            I was hesitant about the 2inch hole. But said and done it wasn’t really a big deal. Measured, double checked, and triple checked before making my hole. I also got 2 strong magnets so I could see exactly where the hole would be inside the engine compartment. Works well no complaints.
            this has some more info: http://www.planetnautique.com/vb3/sh...ria-Conversion
            • 74green
              • Nov 2009
              • 281
              • 2001 Air Nautique
              I added some new pictures to my user album if you want to look. http://www.planetnautique.com/vb3/album.php?albumid=107
              • Hlymons
                • 223
                • Roseville, Ca.
                I would just put perfect pass stargazer. I did a few years back and now I would rather own an older with PP SG than a newer one without. Best money I have ever spent on my boat.
                • Chasstelli
                  • Sep 2010
                  • 8
                  74green and ER906
                  When I purchased the boat new it came with Perfect Pass on it. Does that mean I won't have to drill a 2 inch hole?
                  Like you I'm not crazy about putting a 2 inch hole in the bottom of my boat!!
                  Er906 let me know how your install goes and if you have Perfect Pass?
                  74green the photo's are helpful but I couldn't tell where exactly you drilled the hole. It looks like it is adjacent to the bilge pump? Anything special about drilling? I would think I drill from the outside of the hull to avoid splintering the gell coat.
                  Thanks again.
                  • 74green
                    • Nov 2009
                    • 281
                    • 2001 Air Nautique
                    I would call white lake. I believe if you have PP you do not need to drill a 2inch hole and just do some electrical connections into the PP system.
                    I drilled according the locations on the DIY section which was 106” from the transom and 4” off the keel stbd side.
                    Here is the kit instructions posted from the DIY I believe it refers to PP install in it. http://www.planetnautique.com/vb3/at...5&d=1269651799
                    • ers906
                      • Feb 2010
                      • 921
                      • Phoenix AZ
                      I will post pics and instructions when I get it in (hopefully on tuesday if all goes well)
                      Eric, Phoenix AZ
                      2002 Super Air
                      • rbalan
                        • 328
                        • Georgia
                        • 2002 SANTE
                        I just replaced my digital tach with stargazer. Both the tach and speedo were going bad and I will later replace the speedo with one that uses the pitot tube.
                        Now that we have the PP display, we don't even glance at the speedo or miss the tach. It displays rpms, actual speed, desired speed, engine hours, and even a clock. It really negates the use of a tach or speedo other than a back up. The only reason I will eventually replace the speedo is because I don't want something "nonfunctional" on my boat. I just can't see spending too much on something I don't plan on using nor drilling a hole in the boat for.
                        • Chasstelli
                          • Sep 2010
                          • 8
                          rbalen
                          What is stargazer? I haven't heard of that before. Could you direct me?
                          • rbalan
                            • 328
                            • Georgia
                            • 2002 SANTE
                            Its GPS based Pefect Pass. No need for paddlewheels/drilling holes.
                            • 74green
                              • Nov 2009
                              • 281
                              • 2001 Air Nautique
                              http://www.perfectpass.com/download/...Wake-Flyer.pdf
                              ^ here is some info about it. It is perfectpass's latest product. GPS controlled and not paddle wheel. Starts at $1200.
                              You stated you already have PP on your boat. Does it still work?
