Steering Rattle in a 2010 - 230
  • boatbuddy
    • May 2007
    • 109
    Anyone had problems with a rattling noise under dash at steering wheel at higher speeds?
    We had the steering linkage replaced and most of the noise disappeared but it is still there "slightly" at higher speeds.
  • robertsmcfarland
    • Oct 2004
    • 544
    • Hyco
    • 2014 g23 550
    My 230 seems to be doing fine, I do have a crack tower and White Lake is in discussion with the manufacture for a replacement but David said they are saying miss use, White lake and the correct craft warranty department both agree it needs to be replaced so the heat is on for the manufacture to send a fct3 replacement.
    2013 G23 super air
    2010 230 super air
    2009 220 super air
    2008 210 super air
    2005 210 super air
    2003 calabria pro air
    • swankster
      • Aug 2010
      • 1052
      • DFW, TX
      I have the same problem, now (220 hours). It stared last week and I'm trying to track it down. I put on a new prop and was testing the RPMs at different speeds and noticed it. I don't normally run at high speeds so I'm going to put on the old prop and see if it still occurs.
      2010 SANTE 230 343 (280hrs)
