Dual Battery Setup ?
  • wantanautique
    • Aug 2010
    • 8
    I recently purchased a 96 sport nautique. It only has a single battery andc urrently there is a amp/Sub wired up. I am not thrilled of the idea of having the same battery to run the stereo has to ignition to start the boat. Is there a write up or some information how to change from a single battery setup to a dual battery setup. I see the another compartment in the bow for another battery. Is it a matter of wiring another one or does the alternator needed to be upgraded etc?
  • 74green
    • Nov 2009
    • 281
    • Canyon Lake, Texas
    • 2001 Air Nautique
    My alternator handles the two optima blue tops & two amps just fine.
    You have a couple of wiring options.
    1. Paralleling the batteries.
    2. A Perko Switch or equivalent. This is a manual "1, 2, ALL" switch
    3. Voltage Sensitive Relay. This is like a automatic switch in a sense.
    There may be some other options other PN member have done.
    Current: 2001 Air Nautique GT-40
    • xrichard
      • Aug 2008
      • 669
      • El Dorado Hills
      • 2023 G23
      My boat came with dual batteries but only a 1-2-both switch, which made combining/isolating a manual affair. I installed a Blue Sea Systems switch+ACR and would recommend that set up. If you go to their site, there is some good reading re: dual battery set ups. Another popular ACR is one by Hellroaring. FWIW, I have friends with both setups and neither have had problems.
      http://bluesea.com/productdocs/7650
      After talking with Blue Sea technical support, I ended up wiring mine a bit differently than shown in the manual: instead of wiring the ACR directly to the batteries, I wired it to the load-side of the switch--that way, turning the switch to "off" isolates the ACR from the batteries, which allows me to put a charger on each battery without combining the two via the ACR.
      Previous boats:
      2015 G23
      2008 SAN 210
      2002 XStar
      1995 Sport Nautique
      • ffmedic74
        • 835
        • Lexington, KY
        I just had to do this on my boat. PM me and I will give you the details.
