Just got my three new pumps for $300. Just like she said, brand new with green impellers!! Now the winter project can begin! Now I have to find some rocker switches.
Just got 3 as well, even though I only needed one. Did some research with WakeMakers and ITT before buying to make sure what I was getting, learned alot about part numbers and what they can tell you with these pumps. I think you can get 1 for $130 or so and 3 for $300. I have the old black impellers in my 06 220, one went bad so I priced a new pump with two new green impellers for the other 2. Woould've been about the same price and I got 2 extra pumps!! Only bad thing is the box she shipped them in said, "Genuine Mastercraft parts" on it......
From my research all you have to do is cut the plug off of your orignial pump, cut the Mastercraft plug off of the new pump, connect orange to orange and black to black using the old plug. I will use the heat shrink over my new connections. I did take both plugs apart and found that if you can find the pins that are crimped to the old pump wires, you could cut off the new pulg and crimp new pins and use the body of the old plug, this would only keep you from having connections that could be exposed, but where the pumps are located I dont see that being a problem. They are the right pumps for your boat, the part number is different because they have Mastercraft specific plugs. Hope this helps.
