I am sure this topic has been covered but I don't have time to do a search. What method have you guys found to be the best for cleaning the carpet??? I was thinking I could hit it with pressure washer then wet vac.
Tags: None
Steam cleaners are great. If you want to get it perfect, you could take it to a drycleaners and see what they could do. I had a nightmare keeping mine clean. I kept a can of spot shot on my boat all the time.2012 Axis A22 - on order
2011 Axis A22 - sold
2010 SANTE 230 - sold
2009 SANTE 230 - sold
2008 SANTE 230 - sold
2007 VLX - sold
2002 XStar - sold
1990 Prostar 190 - sold
www.chattwake.com
Pressure washer and wet vac work great. Careful with the pressure washer, you can literally punch a hole through the carpet.
I finally broke down and purchased a professional auto steam cleaner. I think I paid around $600 for the unit which is not cheap but the results justify the cost. Amazing at getting out dirt and stains.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
My concern with steam cleaning is the rubberized underlayment. I thought maybe the heat from the steam might damage it.
Just an update for future reference. I laid the carpet out on the concrete and sprayed it with the hose and and a good coating of Resolve carpet cleaner and let it soak for about an hour. Then I hit it with the pressure washer and the wet vac and it came out looking new again.(it was pretty stained)
