Can anyone tell me where the seacock valve for the launch control system is located on a '99 Sport?
If you mean the ball valve that opens up the thru-hull, there aren't any on a 99 Sport (at least not factory). If you mean a 99 Air, it is in the front of the engine box compartment slightly on the port side.
If you mean the 2 knobs that open up the vent lines so that water can come in and out of the ballast tanks (based on pressure), they are under the throttle pad, slightly behind where the throttle is located.
If it's an after market system, it could be anywhere. I put mine near the rudder linkage in the wayback under a piece of removable floor.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
