Shifting into gear on trailer?
  • gride
    • Jun 2007
    • 1441
    • War Eagle
    • 05' 210 team
    Can I for my trans or is it bad?
  • mdvalant
    • Jan 2010
    • 155
    • IA
    • '90 Ski Nautique '00 Sport Nautique 75th
    Why would you want to? For a very short time it is ok, but don't leave it there. Packing needs water, so does the shaft-thru-strut
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      You're supposed to shift before changing says manual
      • mdvalant
        • Jan 2010
        • 155
        • IA
        Oh you're talking about changing your trans fluid? Sorry, I misunderstood. I'm not sure on that, although I have my manual sitting in front of me. I may check that out.
        I'd say follow your manual and you should be safe.
        • CAN'TSKI
          • Feb 2007
          • 205
          • Boerne, TX
          • 2008 196 Limited 2007 211 Team 1995 MC Prostar 190 Tournament
          Lost me.
          • gride
            • Jun 2007
            • 1441
            • War Eagle
            • 05' 210 team
            Trans. Change per manual-with boat on shift forward, neutral, reverse, neutral. Just checking to see if it's ok to do this on trailer hooked to a hose.
            • BrennanK
              • Feb 2009
              • 348
              • Hopkins, MN
              You might consider elaborating on your question and speaking in full sentences. That way people can understand what you are talking about....
              Be aware of the strut bearing, you will burn that out with extended out of water use.
              1997 Ski Nautique
              • gride
                • Jun 2007
                • 1441
                • War Eagle
                • 05' 210 team
                I'm on an iPad. Suck for typing. I guess I wanted to know if once forward and once reverse will be ok?
                • AirTool
                  • 4049
                  • Katy, Texas
                  before changing or before "checking" ???
                  for changing the engine is OFF.
                  • Quinner
                    • 2246
                    • Correct Crafts
                    LOL, now that makes sense!!
                    • IMPACT-EV1
                      • Jan 2011
                      • 86
                      • indy
                      well typically you don't shift the boat into gear while on the trailer for the reasons mentioned, you destroy the rubber bearing in the strutt and burn the packing flax.
                      for what you are wanting to do
                      change the fluid and cycling the tranny so that the fluid is warm and drains a little better from the internal parts. But to do this you will need to disconnect the coupling so that the prop shaft doesn't move when you engage the transmission, other wise you need to dip it in the water warm the fluid up running it in gear and then draining it as quickly afterwards as possible. That is if you want to follow a book.
                      But all you really need to do is drain it and then fill it and then when you take it out for the frst time you need to check the fluid level before you unhook the boat from the trailer.
                      • gride
                        • Jun 2007
                        • 1441
                        • War Eagle
                        • 05' 210 team
                        Thanks. I'll just warm it and change it and bring extra when I go out.
                        • AirTool
                          • 4049
                          • Katy, Texas
                          Following this procedure, the fluid will never get hot because there is no load on the transmission. They only generate heat when loaded.
                          Now it might stir up and suspend the sediment....but "heat" is unlikely.
