Road Runner Trailers
  • boatbuddy
    • May 2007
    • 109
    We have a Road Runner Trailer and everytime we launch the boat the the Foam and Plastic Pipe which covers the Boat Guides (or whatever they are called) float up and expose the steel pipes
    Seems like there is fastener missing to hold these in place or something is not right
    Any ideas
  • east tx skier
    • 1561
    • Tyler, TX
    I don't think it's a problem. Between your fender padding and your bunks, I don't believe the exposed pipe below the waterline have muchnchance of contacting your hull, particularly since the PVC piece will contact your rub rail first. Mine do this on my Dorsey and it has never been an issue.
    • TX-Foilhead
      • Mar 2009
      • 351
      • Kingsland TX
      No problem as long as they aren't floating away. It shows you where the trailer is at a steep ramp. If you want to try it without the float take the cap off the top.
      • ski4evr
        • May 2010
        • 613
        • Bowling Green, KY
        • 2005 SV 211
        I use a couple of black bungee cords and black tyraps. Mine floated off one time and one time only. The bungee allows the pad to roll if she hits it a little hard to one side.
        2005 SV-211
        • obd666
          • Feb 2010
          • 793
          • Bostian Heights, NC
          • 03 SANTE
          they do it on my ramlin too since they are just capped pvc pipes. but on mine if they are able to float off of the poles i am in WAY too deep with the trailer ...
          2003 SANTE - "OG 210"
          • oakfu
            • Apr 2009
            • 54
            • Englewood, Fla.
            • 1997 Ski Nautique 176
            Mine float up and I use that as a guide to how far down the ramp I am for loading. I don't go deep enough for them to come off. Once I pull out I just press them back down.
            '97 Ski Nautique 176
            • Chexi
              • Feb 2025
              • 2119
              • Austin
              • 2000 SAN
              I always thought there were supposed to do that.
              Now
              2000 SAN
              Previously
              1999 Air Nautique
              1996 Tige Pre-2000
              • xrichard
                • Aug 2008
                • 669
                • El Dorado Hills
                • 2023 G23
                It doesn't hurt if they float up (as long as they don't float off), but I hold mine down with bungie cords attached to a hole I drilled in the pvc pipe. I also drilled a hole in the cap to vent the air.
                Previous boats:
                2015 G23
                2008 SAN 210
                2002 XStar
                1995 Sport Nautique
                • ers906
                  • Feb 2010
                  • 921
                  • Phoenix AZ
                  I also drilled a hole to keep them from floating too high. My understanding was that the PVC was there as protection around the steel guides and allow them to freely rotate as to not damage the boat when launching or retrieving.
                  Eric, Phoenix AZ
                  G23 550 hp (finally here)
                  2002 Super Air
