I think it might be a bad battery if you have to keep a charge on. I have never put a battery charger on any of my boats and they stay out side year round ,covered boat slip. Run stereo all the time, even a lot while the engine is off , just make sure you always use the toggle switch (all-power off} when you are finished for the day.
Interesting discussion. I've had a couple of instances where my batteries drained in a 2 - 3 week period of sitting, I think primarily from the bilge pumps running after heavy rains (and w/ factory cover, prior to getting a Coversports). Hopefully so much running of the bilge pumps is now a thing of the past. Last summer I alternated batteries, running on A for a day, then B the next outing, and A+B while sitting (rather drain both batteries than find a sunk boat).
GCsuper, which onboard charger are you using? Happy w/ it?
Wakeslayer, you don't have to charge your batteries in the spring? They maintain a charge over the winter?
Originally posted by SkiTundra View PostWakeslayer, you don't have to charge your batteries in the spring? They maintain a charge over the winter?the WakeSlayer
1968 Correct Craft Mustang
Originally posted by SkiTundra View PostInteresting discussion. I've had a couple of instances where my batteries drained in a 2 - 3 week period of sitting, I think primarily from the bilge pumps running after heavy rains (and w/ factory cover, prior to getting a Coversports). Hopefully so much running of the bilge pumps is now a thing of the past. Last summer I alternated batteries, running on A for a day, then B the next outing, and A+B while sitting (rather drain both batteries than find a sunk boat).
the books say that you should not leave the chargers on unless well ventilated?? i think if a battery were to go you would be equally as F'd weather the cover was on or off.
if i had a boat that i left outdoors and covered, i would have no problem running a cord and a charger under the boat. if anything the heat of the charger would keep some moisture out of the boat.
-keegan
