We have a new Nautique with the LINC system and I can't get the clock set. It always says 8:00 Eastern. I've gone through all the menues and can change between 12 and 24 as well as change the time zone. I believe it is reading from the GPS. Any ideas on what I'm doing wrong?
Is the boat outside where it can get a gps signal or is it in a garage? If it is inside, it may not have the gps signal that it needs to get the time. If it is outside, you may have a gps error. Go into the diagnostic screen on ZeroOff and look for gps errors. To get there hold the "on/off button down for a couple seconds until the menu pops up on the top row. use the up/down arrow buttons to select the left most choice (can't remember the title without seeing my ZeroOff head unit). Push the select button, use the up down arrows to scroll down to "diagnostics", then hit the select button again. The serial number and software version will show at the top of the screen. If any errors are present they will be listed right below that info. If you don't have a seperate ZeroOff head unit (linc display only), I don't know how to pull up the diagnostics for ZeroOff.
Dave2019 Ski Nautique 6.2 arriving soon
16 other Ski Nautiques
3 MasterCrafts
18 Ski Supreme's
1 SlickCraft Squirt Boat
A d m i n i s t r a t o r
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Mine shows 8:00 if the engine isn't running. Does the clock show the correct time when you start the engine? Mine does.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
I checked last night and I think I may have a bad GPS Puck. I am getting a GPS 1 Failure code in Zero Off. Zero Off worked fine the last time we skied but I didn't have a course mapped since we were using a portable course at a different site. Does anyone know if I won't be able to map a course with only one puck working. I had a puck go bad in our last boat as well, anyone else have issues with these?
One other qeustion on the LINC. Is it true that the air temp does not work? Thought I had heard that and ours reads blank.
- Mar 2002
- 16521
- Lake Norman
- Mooresville, NC
Air temp has worked fine on my last two boats.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
- Jan 2011
- 119
- Overland Park, KS
- 2011 SANTE 230 Coastal Edition - April 2011 to now 2006 Ski Nautique 196 Limited - February 2007 to March 2011
Unlocked vs. Run Mode
I think this is a Run Mode vs Unlocked Mode issue. I was confused by this as well... Everything looks to power up when you go into unlocked mode but the clock, date, and maybe some other stuff I haven't found yet is either blank or populated with dummy data. If you press start one more time to go into Run Mode (you don't need to start the engine) all the dummy data updates to real data.Derald
2011 SANTE 230 CE (April 2011 - now)
2006 SN 196 LE (February 2007 - March 2011)
Watching this thread with interest as I have the same issue with the clock on my 200 OB team. Been through the manual and cannot get the time correct.2010 Ski Nautique 200 Team Edition Open Bow, Radar Strada
Dealer: http://www.midlandsnautique.co.uk
Originally posted by JAW View PostI checked last night and I think I may have a bad GPS Puck. I am getting a GPS 1 Failure code in Zero Off. Zero Off worked fine the last time we skied but I didn't have a course mapped since we were using a portable course at a different site. Does anyone know if I won't be able to map a course with only one puck working. I had a puck go bad in our last boat as well, anyone else have issues with these?
3 MasterCrafts
18 Ski Supreme's
JAW,
I have a 2014 Nautique 200 Closed bow.
My LINC 2.0 clock froze at 12:36 in the middle of a boating day.
You nailed it. One of my GPS pucks is bad. I found the connections where the pucks connect to the LINC harnesses. When I switched the 2 connections, the clock worked again. From there, I connected each puck individually to each LINC harness spot.
I had to turn the main switch off, then back on, and reboot LINC. With one puck, I had satellites on LINC when it was connected to either LINC harness spot, and clock time when it was in the one LINC harness spot. With the other puck, I had no satellites on my LINC display no matter what, and no clock time.
