2007 SANTE 220 hydro gate
  • keegan
    • Mar 2011
    • 66
    • vancouver, BC
    my hydrogate leaver is very loose and will not stay in place. i almost have to hold on to it when i am towing or cruising. i am sure this is an easy fix to adjust the tension. has anyone had to do this?
    thank you,
    -keegan
  • tdc_worm
    • 532
    there should be two phillips head screws on the actual hydrogate at the transom. snug those down just barely to add more friction. that should solve your problem.
    • keegan
      • Mar 2011
      • 66
      • vancouver, BC
      i will give it a try and let you all know.
      thank you.
      • keegan
        • Mar 2011
        • 66
        • vancouver, BC
        problem solved!
        thank you.
