Fct board rack help
  • ajmoritz17
    • Jan 2011
    • 13
    • ohio
    Fct board rack help
    I have a 04 SANTE 210 with the FCT so the rack are mounted on the flat bar it currently has the clip racks that are completely worthless they pinch peoples fingers and only the top ones will hold a board...has anyone found racks they like for these towers that are reasonably priced???? the best i can find is on onlyinboards and they are $550 for a pair. and they are nothing special.. any help is greatly appreciated!
    • Apr 2025
    Out of curiousity, which do you presently have, Flight clips or Nverts?
    You can use any standard rack and just mount it to the vertical tubing instead of the oval crossbar.
    • shonuff
      • Sep 2010
      • 157
      • Atlanta, GA
      • '05 SANTE
      I have the flight clips on my '05 SANTE and I totally understand. It gets old having to climb around the tower to load/unload the boards.
      DIYwake makes a spinner rack for around $200 that I've been thinking about getting. I haven't pulled the trigger yet but I think about it every time I'm loading and unloading boards from my flight clips. I just wish there were reviews out there on these racks.
      2005 SANTE
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        • 2010 SANTE 210 (Sold)
        I picked up these ones
        http://www.menacewatersports.com/
        Though I don't see them on the website, they have (had?) ones that have the Nautique logo (wakeboard with star) on the plate that holds the forks to the spinning barrel. I installed these last fall and they have been a great upgrade from the flight clips (so I too don't have to climb up to access the racks). I bought a third set of forks to hold a knee board but have the WB forks up on both racks now.
        Good quality finish and set up well on my FCT!
        • shonuff
          • Sep 2010
          • 157
          • Atlanta, GA
          • '05 SANTE
          HS- What did you pay for those and do you have any pictures of it mounted on your FCT?
          2005 SANTE
          • HS
            • Oct 2007
            • 1333
            • Sammamish, WA
            Sorry but I can't recall the exact amount; seems like a couple hundred for each. No photos but I'll try to get some.
            FWIW, before I found these, I remember trying to locate spinners from White Lake where they had appeared as a close out special that I missed, and the guy there told me the ones for 211s and that FCT were designed for the angle of the tower -- this is so that the spinner rotated on a level plane.
            • ajmoritz17
              • Jan 2011
              • 13
              • ohio
              I currently have the nverts......
              I guess i wasnt sure of putting them on the tubed part of the tower but i guess that would be better if they were on rear tube and spun around..
              • ajmoritz17
                • Jan 2011
                • 13
                • ohio
                Anyone have any pictures of there racks mounted ?
                • riderite
                  • Jul 2010
                  • 83
                  Star One Wake has clamps for the FCT-2 for spinners, lift off, or just your raegular fixed racks... 916-858-1178... Mention you are a member of Planet Nautique and you might get a little discount.. Star One is Menace Watersports...
                  • ckdollar
                    • Apr 2011
                    • 52
                    • Irving TX
                    • 1999 Super Air Nautique
                    Anyone seen any that are black powder coated?
                      • Apr 2025
                      I have a set of Nverts (never used) that I was planning on drilling holes into on the handle parts and putting knobs so you could grab the knob and use it to open and close (hopefully avoid the pinching problem). Just an idea. However, you said that your bottoms racks don't work anyway, so that doesn't sound like a useful solution for you.
                      I think that spinner racks (or regular tube racks with the diy spinner rack adapter) are probably the best current option out there.
                      • riderite
                        • Jul 2010
                        • 83
                        All Racks are available with the FCT clamps... Here is a pic with lift off...
                        • ajmoritz17
                          • Jan 2011
                          • 13
                          • ohio
                          http://cgi.ebay.com/ebaymotors/Wake-...ssoriesQ5fGear
                          Do you think these would work?
