210 Super Air Team Gauges NOT working except Volt meter and Perfect pass
  • kbachert
    • 2
    • Tipton, MI
    • 2004 210 Super Air Team
    I have been having problems with the gauge NOT working except the perfect pass and voltage meter.
    the gauge lights don't work either except voltage meter
    Started with the fuel meter not working and then the whole panel went out
    Any suggestions
    2004 Super Air Team edition 210
    Thank you
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Check under the dash pod to make sure the wiring harness is connected and snug. It is possible that it was loose and has worked it way off over time, with the fuel gauge pin being the first to be disconnected. Just a thought.
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
    • TRDon
      • Oct 2007
      • 722
      • MN
      I hope for your sake it isnt the gateway going out. It is about a 700dollar replacement. Mine went out last year on my 03, did what you are discribing. Check the connections, they are serially connected with a 4 wire and jumpers that goes back to the gateway that feeds the information tot he gauges.
      • kbachert
        • 2
        • Tipton, MI
        Everyone, THANK YOU
        I took the dash apart and checked all the connections.
        I took all of the nylon tie staps off and check all of those connections.
        Now everthing works!!!!!!!!!
        AGAIN THANKS to ALL who responded
        Kevin
