Hi guys,
just wanted to confirm a few things about the stock ballast in my boat.
So in my 2005 SANTE there are some valves under the dash. In the manual it says to open those valves to fill the ballasts and press the dashboard button corresponding to the ballast you want to fill. The light will stay on when filling.
That part seems ok as I did get the ballasts full. I'm having more of a problem with the emptying part. The process seems the same, open the valve and press the button but this time it should flash when emptying? The button doesn't flash on the dash but there is water coming out the back. After about 10-15 minutes of water coming out my gauge still indicated it was full??
Am I doing this right? Is there an order of things I'm not doing properly?
Also does it have to do with the ballast kind of lever thingys in the front of the engine compartment? Should those be set to open all the time? when should they be in the closed position?
Thanks!
Thanks!
