they do adjust for octane.
I don't know what's recommended for these engines, but you have to understand what higher octane does. It actually slows down combustion. So, sometimes higher octane actually produces less power from a given engine. The most power will be achieved from the lowest octane that doesn't produce pre ignition(pinging).
You want to be at the optimal point of no pinging and getting the most energy out of the explosion of the gas.
If your octane is too low, then timing is retarded so as to avoid pinging, again robbing power.
