It sounds like you may be looking for a softer "pull" rather than a softer wake/rooster? Thats an important distinction.
I guess the real question is whether the 422 was an improvement over the stock 14x16 in that regard. If it was, then theres a chance that going to an even shorter prop (like the 3-blade 470) might improve things. Though, my understanding was that shorter props that increase RPM's at skiing speeds would provide a "firmer" pull since they will hold speed a little better and cant be slowed down as easily with a strong pull from a skier. Of course, they shouldnt need to catch up if theyre not getting pulled down either... so I can see that argument too.
Honestly, Im not a good enough slalom skier to notice the difference of subtle prop changes like that... so perhaps someone else can weigh in on the topic.
Im sure you have already played with the Stargazer settings that would have an impact on the pulls firmness?
