Hey guys I plan on re powering my current 2007 196 with a new 6.0L, the 5.7 that is in the boat now has 350 hours on it now and is is perfect condition. If someone is interested in this engine it can be purchased for 5900.00.
Tags: None
Might I make a suggestion. We foot my 196 with 5.7 (run 43.5 with 2 in boat is a 220# behind) at 100 feet. I'm sure you foot your boat and know the wake isn't great at any line length.
I suggest taking the 5900.00 you are going to put into a new motor and buy a barefoot boat. We picked up a 92 flightcraft for 8K about 3 years ago. Inboard. At 70 feet it is awesome. We also ski a 94 Malibu Echlon with a 454 which will run 54 with 4 in the boat and 2 footers. My flighty will run 44 with 3 in the boat and 220 footer. You will get a much better wake.
I back slalom at 47-48 mph,the 196 with a Acme 15 pitch 3 blade is running 47 with just my wife driving and me in tow (225lbs). Which is fine but when we add one more person to the boat the speed drops to 46. If I add a barefoot plate it will drop it another 2mph. I feel that I add another 80 horsepower it will solve the top end problem. If the motor or boat doesnt sell soon it will be replaced with a new Sanger DXII.
Originally posted by coosafooter View PostI feel that I add another 80 horsepower it will solve the top end problem.
An improvement would be another 1500 rpm or a much higher pitched prop that will get your engine down in the sweet spot where it does have some power. That 6.0L would help with RPM.
I've posted before...a desire for a two speed tranny.
Problem is...that boat is just not designed to go that fast.
I'm with Crad, get a barefoot boat. I thought it as well when the thread popped up but wasn't going to say it. I won't tell you what I'm shopping for but its not a DXII.
Originally posted by AirTool View PostThat won't do it. It is not a shortage of available horsepower. At WOT and max RPM, your engine is producing a relatively low amount of horsepower.
1. At WOT (max RPM), the engine should be very close to operating at its peak hp. The Excal makes peak power right around 5000 RPM.
2. Trying to spin the engine 1500rpm higher (~6500 RPM) would yield aweful top end (it is too far past the engine's hp peak) AND decrease its reliability.
3. Going to a higher pitch prop would LOWER (not raise) the WOT RPM's and would also negatively impact the top end, as well as hurt holeshot.
The goal is to prop the boat such that achieves a WOT RPM that is as close as possible to where it makes its peak hp. Correct Craft historically has done a pretty good job at this on their ski boats. Modern wakeboats are propped more for holeshot and their max RPM's are capped by a rev limiter, but thats another discussion altogether.
The 6.0L will in fact improve top end significantly. The 46-47mph that the Excal boat is capable now is very strong... are those numbers GPS? Im assuming that the hydrogate is up (trick/jump) as my father's former 196 (TSC2) was only good for 45 or so with no footer behind it. We havent tried to see how fast his new 196/409hp will pull a footer, but Id bet that its 50+, as its good for 53mph any given day, and has seen excursions up to 57mph with some weight in the back and ideal water conditions.
As far as a wake plate goes, I think you will have a very hard time finding something that will work on a 196 hull... it is not a flat bottom boat, especially in keel. You would be better off trying different positions of the hydrogate. Im not sure how much effect a plate would have on the wake other than changing the running attitude of the hull (bow down), which is what the gate does.
I think that trying to get $5900 for that Used Excal is going to be a very tough sell...1990 Ski Nautique
NWCT
Yes I am using my new perfect pass for speed, Acme built the prop just for barefooting. I understand fuel injected motors and there is no way possible to get any more RPM. The 6.0 is the way to go, just trying to sell the engine that I have. I also have been playing around with a narrow plate the width of our keel. I just feel like adding 80 horsepower should increase the speed 7-8 mph.
Originally posted by coosafooter View PostHey guys I plan on re powering my current 2007 196 with a new 6.0L, the 5.7 that is in the boat now has 350 hours on it now and is is perfect condition. If someone is interested in this engine it can be purchased for 5900.00.
What comes with the motor for that price?
Originally posted by coosafooter View PostYes I am using my new perfect pass for speed, Acme built the prop just for barefooting. I understand fuel injected motors and there is no way possible to get any more RPM. The 6.0 is the way to go, just trying to sell the engine that I have. I also have been playing around with a narrow plate the width of our keel. I just feel like adding 80 horsepower should increase the speed 7-8 mph.
I dont doubt that there is a way to tune that Excal to get a few more ponies, but that sort of project is probably not for the faint of heart.
I would be interested in seeing the plate that youre using, as well as pictures of the wake for comparison. Im not sure how it would affect the wake other than how it adjusts the boat's attitude (running angle), which the hydrogate already does. I assume youre installing it on the narrow part of the keel, at the level of the hull (hydrogate up- trick/jump)?
80 extra hp will not buy you 7-8mph... more like 5mph. The consensus seems to be that the 409hp 6.0L will generally push a 196 to 52-53mph with the gate up (unloaded).
Which prop did Acme recommend for barefooting on the Excal/196?1990 Ski Nautique
NWCT
I considered repowering my 211 with a custom built 400+ cube motor. I advertised my 330EX here and other places. I had zero reasonable offers. I have now have a second boat...
The prop is 12.5 dia. X 15 pitch w/.150 cup 3 blade. I am using the star gazer no paddle wheel. The plate has been trashed, no change in wake shape, same wake produced using hydra gate.
Originally posted by coosafooter View PostThe prop is 12.5 dia. X 15 pitch w/.150 cup 3 blade. I am using the star gazer no paddle wheel. The plate has been trashed, no change in wake shape, same wake produced using hydra gate.
I cant say Im surprised that the plate didnt help you... the hydrogate does a great job of adjusting the running attitude of the hull.1990 Ski Nautique
NWCT
I spoke to Acme today we discussed going to the larger 13.25 diameter they explained that the larger diameter may hold the speed better than the 12.5 diameter.
Originally posted by coosafooter View PostJust a note, need at least 1'' clearence between prop and hull.
Going from memory, I think the TSC2/3 196 should have clearance for the 1442 (13.25" diameter) prop. Measure your clearance now and see if you can tolerate losing 3/8".1990 Ski Nautique
NWCT
