On Board Battery Charge Option ??
  • ccs
    • Sep 2011
    • 231
    • Greensburg, PA
    • 2012 SAN 230 - On Order (spring delivery) 2003 Nautique 226 - previous
    Anyone have any experience or knowledge on the Nautique 230 On Board Batter Maintenance (charging) system ?
    Any pics of how you plug into it or just general info as to whether this is a good option or ??
    __________________________________________________
    2012 Super Air Nautique 230 Team ZR409
  • Madhat78
    • Dec 2005
    • 105
    • NorthEast
    I have not seen it in the 230, but have seen it in the Sport 200. Very simple system. It is just like have a trickle charger permanently mounted in the boat. You need to run an extension cord to one of the aft storage compartments and just plug it in. meant for when the boat is in a boat house/lift or on it's trailer mainly. It does not run like a shore power kit.
    • ccs
      • Sep 2011
      • 231
      • Greensburg, PA
      where do you plug into it at? Its not another hole drilled into the outside of the boat is it ? (through the gelcoat I mean)
      • DJH
        • Jan 2011
        • 119
        • Overland Park, KS
        • 2011 SANTE 230 Coastal Edition - April 2011 to now 2006 Ski Nautique 196 Limited - February 2007 to March 2011
        The charger is installed in the storage compartment with the starboard battery. The plug in for your extension cord is mounted in the wall between the battery storage compartment and the cooler storage. You plug in in the cooler area. There are no extra holes in the hull.
        Derald
        2011 SANTE 230 CE (April 2011 - now)
        2006 SN 196 LE (February 2007 - March 2011)
        • ccs
          • Sep 2011
          • 231
          • Greensburg, PA
          DJH -
          you have this on your boat ? like it ?
          Our boat never on a lift as we trailer most of time. Only thing I can think of where this is of use to me is to plug in and leave all winter ? (like a trickle charge) ? or can you not leave it in that long.
          Im assuming if both batteries went dead, plugging into this system is not best way to get boat started, more like a jump pack in that situation as this seems to be more of a trickle system not a jump start system ?
          • Blue Ski
            • 164
            Seems like an expensive way to avoid the annual chore of taking the battery out and storing it inside on a trickle charger for the winter.
              I like in western Oregon, and the Winters are milder here than most of the country, but I just disconnect the negative battery cable. In the spring, when I recommission the boat, I hook up 6 amp battery charger, and usually by the time I am ready to start the engine, after hooking everything up, and putting plugs back in, the charger has dropped to a less than 2 amp rate, and I start the boat.
              If your battery will not hold a charge over winter, disconnected, it probably is not a reliable battery to start the boat with next Summer. I would replace it.
              • 2004196
                • Dec 2007
                • 162
                • University Place, WA
                • 2006 196LE
                I have a battery tender (charger/maintainer) I purchased on line for around $25, mounted it in the battery compartment and wired to the battery terminals permenately. My boat sits on a lift and I plug it in after each use, have done this for 7 years. I use the boat 2 - 3 times a week in summer, I am not really concerned about the battery going dead, this just keeps it full. The battery charger stays pluged in all winter, the boat will get used 2 - 3 times a month all winter. My two ski buds also do the same thing as we trade off the boat we use each outing and no one has had a problem with the chargers, a dead battery or any battery issues at all. We all have extension cords on our lifts we can quickly plug the chargers into, never have to disconnect or remove the battery. Two of us have Optima and one has a Diehard.
                2004 196 LE Black/Grey
                330HP Excalibur Water Churner
                2002 Grey F150 Harley
                475+HP Supercharged Tire Burner
                • ccs
                  • Sep 2011
                  • 231
                  • Greensburg, PA
                  sounds like a "no thanks" for me on this option - -
                  Just got my email today from my Nautique Dealer - final change date 10/31/11 for my 230 build - should be build November with a Dec 1 completion date - going to get some production pictures and will post.
                  • AirTool
                    • 4049
                    • Katy, Texas
                    WOW that is fast. Did your dealer have a slot for you already?
                    I'm with DanielC as usual. One suggestion I would make to all...based on the fact that RARELY (if ever) is your battery actually fully charged even after a long boat ride with no accessories on. That is just the way the system work. So, at the end of the season, put your charger on the battery and top it off. That will further reduce sulfate production, discharge, etc. and you're battery should be just fine when you springerize (Copyright!!) it. I (again like DC) put the charger on for the first use. Why?....dunno. I usually pull the kill switch and crank it before I do and she has always cranked.
                    • ccs
                      • Sep 2011
                      • 231
                      • Greensburg, PA
                      Airtool--
                      Yes, "gave" them the order back in early September....knowing we were going for a Nov-Dec build.
                      • AirTool
                        • 4049
                        • Katy, Texas
                        Airtool--
                        That's pretty good even if they didn't have a slot(s) already reserved. Some (most?) dealers have their slots per hull scheduled and if they don't get a special order in time, they spec it out for their inventory.
                        • msbowhunter
                          • Aug 2011
                          • 100
                          • collierville tn
                          • 2011 SAN 210
                          A $25 Bettery tender will do same thing!
                          • DJH
                            • Jan 2011
                            • 119
                            • Overland Park, KS
                            DJH -
                            Our 230 was a dealer demo so they had it loaded with options. The charger is nice but I doubt I'd spring for it if I were building the boat up myself... we had our 196 for 4 years and never once put a charger on it - disconnected the battery during the 5 month lay up and ran it regularly during the season - never had an issue.
                            For other who are interested, the factory charger is the ProMariner ProSport... I can't remember if it's the 12 or 20 Amp version - dual battery.
                            Derald
                            • MrJake
                              • Mar 2004
                              • 73
                              • Bellingham, WA
                              • 2013 200V Team Edition 1979 Ski Nautique
                              Reviving this old thread.
                              I purchased a 2013 Sport 200V back in January. It came with the ProMariner ProSport 8. Problem is, the plug used to plug the tender into the extension cord is missing. The plug on the end of the charger is a female desktop computer style plug. The one with the three vertical prongs. Does anyone else have this style of plug and can I just use a computer cord / cable to plug the tender into a normal extension cord.
Name:	ProMariner ProSport 8.jpg
ID:	591181Click image for larger version
Name:	ProMariner Adapter.jpg
