Towing with the lifting ring
  • macstac
    • Oct 2010
    • 8
    • Sydney, Australia
    • 2007 Super Air Nautique 210
    Hi
    Has anyone used the lifting ring to tow with? Is it possible or will it cause damage?
    I would like to tow a tube/biscuit from there if it isn't going to cause any damage.
  • SkiTower
    • 2172
    • Clayton, NC
    there have been a LOT of threads on this subject. Some do, some would never. Bottom line is this is designed for a vertical load, not horizontal.
    2007 SV211 SE
    Tow Vehicle 2019 Tundra
    Dealer: www.Whitelake.com
    • swc5150
      • 2240
      • Eau Claire, WI
      • MasterCraft Prostar
      I would maybe pull a small child on a pair of combos using the lifting ring, but not a tube. The drag of a tube puts way too much pressure of the towing appartus. Like ST mentioned, you'll conflicting opinions on this, but it is only designed for vertical load - there is no conflict on that reality.
      '08 196LE (previous)
      '07 196LE (previous)
      2 - '06 196SE's (previous)
      • ccs
        • Sep 2011
        • 231
        • Greensburg, PA
        • 2012 SAN 230 - On Order (spring delivery) 2003 Nautique 226 - previous
        I assume the above opinions reflect the lifting ring only and not the new pop up pylon / lift ring combo ?
        Its my understanding that this combo is rated and fine for use with towing as well as the vertical lift...correct ?
        __________________________________________________
        2012 Super Air Nautique 230 Team ZR409
        • Quinner
          • 2246
          • Correct Crafts
          Interesting, did not realize they have combined those functions on some models, great idea!
          Would be very interesting to see a photo comparison from below deck of the connection/reinforcing of these (3) types: a typical lift ring, a combo lift/tow ring and a rear pylon/tow point.
          The only model I am aware of with a rear pylon/tow point is the 93' Ski Nautique (would imagine the 90' thru 96' would also have one).
          I am of the opinion, other then tube(s), most anything else that would not create a very large sustained resistance "should" be OK to pull from a lift ring.
          • AirTool
            • 4049
            • Katy, Texas
            I don't think so. IIRC the pop up tow point is separate from the lift point. Someone that owns one can confirm.
            • ccs
              • Sep 2011
              • 231
              • Greensburg, PA
              I dont think they would advertise this combo as a lift ring / pop up pylon unless it were solidly capable of pulling skiers / tubers etc etc. as well as utilized as a lift ring - - the cool thing is it cetes itself and becomes flush with the back of the boat to be out of the way so as not to stub your toe on it
              - - Im looking for a couple good pics to post (one below shows it down in, flush with boat) - now need one of it up showing lift ring and pylon exposed.
              ....Based on what I read, this combo was not available until 2011 (not sure exaclty what models) but ordered it on our 2012 Team 230.
              • ccs
                • Sep 2011
                • 231
                • Greensburg, PA
                Heres a picture with the lift ring / pop up pylon in the up position.
                • SkiTower
                  • 2172
                  • Clayton, NC
                  Yep, the tow/lift combo they have now is very sweet, and to answer AT it is all one piece (at least on what I've seen). Yes, I think they would design it for towing forces if they added the towing feature. But anything more than a single tube would be suspect.
                  2007 SV211 SE
                  • shag
                    • 2217
                    Actually, I would tend to think that the new tow/lift combo might even be more secure than the tower.... And I have it in my 09 230.
                    • EntiatSkier
                      • 82
                      • Orondo, Washington
                      • 1998 Ski Nautique
                      [ATTACH=CONFIG]15517[/ATTACH]
                      That looks exactly like the one on the Ski Nautiques... My 98 SNOB has that same pylon but it doesn't popup or go down...
                      1998 Ski Nautique Open Bow
                      Perfect Pass / Z Box / 66" HO S1 / HO Attack
                      - My Other Toys -
                      2002 Schwarz ///M3
                      2004 Silbergrau Metallic BMW 330
                      • SkiTower
                        • 2172
                        • Clayton, NC
                        If it has a feature at the bottom for the rope, I'd be more inclined to use it. But personally I would still see what CC says about it. And still wouldn't put a multi-person tube on it.
                        2007 SV211 SE
                        • bscott
                          • 188
                          • Bolingbrook, IL
                          The Nautique promo video for the Sport 200 shows the boat pulling a tube from the pop-up pylon.
                          • jllogan
                            • Dec 2011
                            • 7
                            • canton, oh
                            • 1986 SN 2001
                            The other issue with towing from a low tow point such as that or the lift ring is the rope often gets caught up in the wake which is annoying if you are trying to get any movement on the tube. I would not personally tow from the lift ring unless it was reinforced. If you look under the deck at what it is connected to I think you would change your mind as well, its not very substantial and doesnt have any real support for a pulling load.
                            • ccs
                              • Sep 2011
                              • 231
                              • Greensburg, PA
                              jlogan - - I'll assume that you must be referring to the "lift ring" specifically and not the lift ring/pylon combo....as Im pretty certain correct craft wouldnt advertise this as a towable pylon without having the proper support structure in place to handle it.
