help hooking up speedo
  • sccadriver
    • Dec 2011
    • 6
    • Charlotte, NC
    • 2003 Air Nautique 216
    OK.....so I bought the 216 and I want to add a few items. The boat originally had an analog speedo but a Perfect Pass Wakeboard Pro was added before it was delivered to purchaser #1. The analog display was removed and the only speed indicator in the dash now is the Perfect Pass digital.
    So I decided to add an additional analog and called White Lake (I'd ask them for help, but their on Christmas break). I got the correct speedo and a jumper they said would allow me to use the paddle wheel from the PP. The original paddle wheel from the factory speedo is still in the floor of the engine compartment.
    Now, with all that being said, I don't have any wiring instructions. Can anyone help me figure out where the jumper wire they sent me connects?
    the back of the speedometer has large multi-prong connectors which dont match the jumper......does the jumper connect from the perfect pass somewhere to the original wire that went from the old paddle wheel to the dash?????
    Hate to show my ignorance, but with no instructions, I'd hate to screw something up!
    Thanks in advance for any assistance.
  • Rick
    • Mar 2004
    • 1250
    • San Diego, Ca
    I did an article on this a few years back when I converted my 2000 Electronic gauges to Faria. The jumper should be a Y and one side replaces the wire from the module to the PP gauge. The other side of the jumper should go into the back of your speedo. Search Faria conversion to see the pictures. Good luck.
    Nautiqueless in San Diego
