All Will Be Revealed 03.31.12
  • AirTool
    • 4049
    • Katy, Texas
    #496
    Originally posted by gride View Post
    Dealers may as well strike a deal with local truck dealers because you're going to need a new one when you get a g23.
    Maybe drain the ballast before you put it on the trailer.
    sorry....couldn't resist.
    • gride
      • Jun 2007
      • 1441
      • War Eagle
      • 05' 210 team
      #497
      I meant that I wouldn't feel comfortable towing it with my 5.7l Yukon. Maybe with new brakes/suspension and some sort of weight transfer device.
      • crobi2
        • Dec 2010
        • 337
        • Texas
        • 2000 Super Air Nautique
        #498
        gride - you know you love that Yukon - that thing lives to tow!
        A 4x4 Yukon with a 5.3 and 3.73 can tow what about 7500# - that should be plenty right?
        Rob
        2000 SAN
        • schaabj
          • Oct 2011
          • 140
          • Canada
          • 2013 Super Air G23
          #499
          What is the top speed of the G23 with the 550?
          • wake_fun
            • 1330
            • CA
            • 1995 Super Sport
            #500
            Pulling it behind my Duramax, no problem
            Photo Album
            Ballast Install 1
            Ballast Install 2
            Amp Install
            PPass Install
            Alternator Install
            • schaabj
              • Oct 2011
              • 140
              • Canada
              #501
              I plan on pulling mine with my Tacoma!
              • TxJole
                • Jun 2009
                • 898
                • Cedar Creek Lake TEXAS
                #502
                Leave the jack stand down.
                • schaabj
                  • Oct 2011
                  • 140
                  • Canada
                  #503
                  Haha .. I got the OME heavy duty suspension. Pulled my 2005 226 over the mountains like a champ! Hardly any sagging in the rear. Im sure the extra 1500 lbs will be fine!
                  • gride
                    • Jun 2007
                    • 1441
                    • War Eagle
                    • 05' 210 team
                    #504
                    I'm sorry I was thinking of my boats engine. I do have the 5.3l with 3.73 gearing tow package. I just got home from towing my 210 on a tandem trailer with half a tank in the boat and I barely notice it. I would want some awesome trailer discs too.
                    • schaabj
                      • Oct 2011
                      • 140
                      • Canada
                      #505
                      What do you think the MAX speed of the G23 will be with the XS550? Will it get up and cruise like a nautique should when the ballast is empty?
                      • tdc_worm
                        • 532
                        #506
                        max sustained cruise speed per PCM's guidelines is at 4k rpm. to that end, i am sure it will cruise at 4k rpm just like any boat should, hahaha....
                        • schaabj
                          • Oct 2011
                          • 140
                          • Canada
                          #507
                          Yes, but also depends on the prop blade angles ....
                          • tdc_worm
                            • 532
                            #508
                            page 56 of the 2010 PCM manual under Engine Specifications advises that the maximum cruise RPM for a 5.0L is 3800 rpm, and the 5.7L and above is 4000 rpm. nowhere does it reference "blade angles," or pitch, which by definition is the displacement a propeller makes in a complete spin of 360° degrees. blade angle, which varies along the blade length, along with cup, diameter and blade shape all contribute to pitch.
                            • schaabj
                              • Oct 2011
                              • 140
                              • Canada
                              #509
                              Okay but the cruising speed of a boat depends on pitch and rotational speed of the prop. A boat with a speed prop will go faster than one with a power prop which is built more for pulling torque...
                              Just curious if the cruising speed of the G23 with the XS550 will be similar to the 230?
                              • Tony_M
                                • Apr 2025
                                • 18
                                #510
                                Has anyone on here ordered one yet?
