1993 diferences between openbow and closed bow
  • derekpfeiffer
    • Apr 2012
    • 35
    • Nebraska
    • 1993 Ski Nautique Openbow
    I have a 1993 Ski Nautique Open bow 19.5' and I'm wanting to order a tower for it. The company that I ordered my tower from only has the template for a closed bow and not an open bow. Does anyone know if the area around the open bow in front of the windshield is the same from an openbow versus a closed bow?? Looks to me that it would be but I hate to gamble and it not be.
    thanks for any info!!!!
    Doogie
    2008 Larson 228 LXI 350 MAG Bravo 3
    1993 Ski Nautique OB (tower ordered)
  • swc5150
    • 2240
    • Eau Claire, WI
    • MasterCraft Prostar
    I believe the windshield is moved back further on the open bow, but with that said, the deck itself is the same. I would think there would be enough "play" between where the tower and windshields are attached to the deck to work with either configuration? However, the contour of the tower may be designed to match the CB windshield, which is different from the OB. Will they take the tower back if it doesn't work for you?
    '08 196LE (previous)
    '07 196LE (previous)
    2 - '06 196SE's (previous)
    • Storm34
      • Aug 2011
      • 36
      • Dexter Iowa
      • 1970 Skier, 1974 Skier, 1978 Ski Tique, 1984 Ski Tique, 1988 2001, 1996 SNOB
      The SNOB's windshield is moved back 9" to accommodate the play pen. I would say that the decks are very similar in style, but very different in their measurements. Assume nothing when you are making this type of purchase. What company did you order from?
      • derekpfeiffer
        • Apr 2012
        • 35
        • Nebraska
        http://www.newdimensiontowers.com/ga...-1996_Ski.html
        It's a new dimension tower. I'm on the fence on what to do. It's mine if it doesn't fit and would have to modify... I really like their towers. Any other suggestions on towers possibly??
        I had talked to the owner of the company and he said he'd make a template for it but was unable to find an OB in the area...anyone know of one in the Friendsville, TN area??
        Thanks again for the info!!!!
        Doogie
        • osukellen
          • Jul 2009
          • 50
          • Edmond, OK
          • 1994 Ski Nautique Open Bow
          I have an aerial tower, and I like it. I think it looks good on these boats also. Very good quality.
          • derekpfeiffer
            • Apr 2012
            • 35
            • Nebraska
            They have some nice towers! Reasonable too! What tower do you have??
            Doogie
            • NCH2oSki
              • 1159
              • Maryville, TN
              • 2005 ski nautique 206 SE
              I was at ND today, thinking about a tower for my 206. I'm sure you gave him your measurements to compare with the CB.....make a mock up with what he has for the cb version and see how it works..... ask him about some critical dimensions that would help.... Let me know if I can help, I'm just about a 15 minute drive from there and I'll be spending some time there if I decide to get a tower...he doesnt have a 206 pattern either.
              Prior Boats:
              1999 Ski Nautique GT-40
              www.skiersofknoxville.org
              • derekpfeiffer
                • Apr 2012
                • 35
                • Nebraska
                Really liking this tower!! Any thoughts from anyone? Good price too....
                http://www.aerialwakeboarding.com/Pr...%2DPA&CartID=1
                Doogie
                • osukellen
                  • Jul 2009
                  • 50
                  • Edmond, OK
                  Don't know about that tower, I have the airborne. Look at my profile and there should be a picture of it on my boat so you can see what they look like
                  • derekpfeiffer
                    • Apr 2012
                    • 35
                    • Nebraska
                    very nice!! How hard was it to get to the front mount bolts?? what did they have for backing plates? I know the new dimension tower I was looking at had resin to glass the bottom plates in. My only concern to the one in my link is the obvious stress in the design versus one that mounts in the front of the windsheild also, but I believe the nautiques top rail his pretty heavily glassed compared to other boats but I may be wrong.
                    Thanks for the info guys!!
                    Doogie
                    • osukellen
                      • Jul 2009
                      • 50
                      • Edmond, OK
                      We used wood for backing plates, and it secure. Front wasn't too bad to get to.
                      If you want, I can take some measurements of where it is mounted and you can send to the other place to see what they can do?
                      • derekpfeiffer
                        • Apr 2012
                        • 35
                        • Nebraska
                        Thanks but I think I'm just going to order the FreeRide tower from Aerial. I called and asked them what deal they could make me on a package deal. $1950 shipped with two racks and a set of speakers...Can't beat that I don't think. Unfortuantely it won't ship till May I need to decide though...Price is only good today he said.
                        Doogie
                        • TX-Foilhead
                          • Mar 2009
                          • 351
                          • Kingsland TX
                          I've got a 93 Excel, so not exactly the same but I would imaging the construction techniques are similar. Under the corners of the windshield there are metal loops glassed in most likely for lifting out of the mold. So that area is pretty reinforced, but not very smooth for backing plates. The gunwhales are not all that thick due to a layer of honeycomb that runs down the center for support. It's plenty stiff, but it I crank down on the tower feet I can hear and feel it compressing. Again it takes a little more work to get a backing plate in there as well.
                          Due to the loads we put on the rear feet from the hydrofoils and the tower speakers I'm thinking about making some larger plates top and bottom to spread the load even more.
                          • osukellen
                            • Jul 2009
                            • 50
                            • Edmond, OK
                            I'd be willing to bet they will give you the same deal tomorrow, or next week. May is only 2 weeks away!
                            • derekpfeiffer
                              • Apr 2012
                              • 35
                              • Nebraska
                              LOL i know my thoughts exactly! Yeah i know but the only days I have off betwen now and Memorial day is next weekend. Would have been nice to get it on then...oh well
                              Doogie
