Received the cover a few months ago from Brent over at Coversports and finally had a chance to pull it out of its box and put it on. The quality looks very good - however, really confused about how to put it on.
Tried calling him, but no answer. I did receive this e-mail from him when he sent the cover out, but it doesn't make much sense to me. Maybe some of you can translate it for me?
"Hi Jonathan cover sports here your cover was sent really rushed to get it out but it looks like it wont get there in time I believe you said by the 6th fed ex drivers were supposedly off today now it wont get there until the 10th. And we didn't have enough time to get the swim deck cover out, will send it in the next couple of days. You will also have to cut the rope for the tower cut outs find that one is cut melted and tied just pull back tight on the rope and make sure it is in the center of the horizontal zipper the cut the front one, make sure it is centered every time pull and center, rope frays so melt ends each time. At the back you will find an option for attaching the back five pull straps, they can go to the buttons that can be installed by removing rub rail screws [ see example on one back strap] or feed through grab handles tow rings etc the preferred way if applicable, Any questions give a call. The cover is tight at first and will take some effort to get it on but it will conform after a while."
The problem I'm having is, after putting it on, the rope that goes from the bow back towards the stern is on the inside of the tower. It needs to be on the outside so that I can zip down the cover around the tower. I don't want to pull the rope out because feeding it through the cover seems very difficult. I've posted some pictures to show you guys the issue I'm having. Describing it is difficult, unless I showed you in person - but the pictures will suffice. Thanks in advance!!
