Has anyone mounted a shower on a 200dd? The person buying mine would like to have one so I'm going to install one soon. Looking to see if anyone has already done it and found a good spot for the hose/shower head/controls. At first glance, I'm thinking in one of the saddle bags.
Shower on 200
Promo Team member
1999 196
2010 200 Team 2010 200 Team
2011 200 Team 2011 200 Team
2012 200 Team - 2012 200 Team
2013 200 Team - 2013 200 Team
2014 200 Team - 2014 200 Team
2015 200 Team - on the wayTags: None
A friend of mine, local promo guy, has put showers in his last couple 200's. He mounted the pump onto the fuel tank bracket. The hose and shower head is in one of the saddlebags. He actually mounts the temp controls inside the engine compartment, figures once the temp is set it doesnt need to be messed with\'95 SN Signature Ed.
GT-40
PP Stargaze
**For Sale**
Mine is installed in the saddle bags. controls in motor compartment.2012 SN 200 Team CB, PCM 343hp, White/Gunmetal
2002 SN 196 Limited CB, PCM 320hp Apex, White/Black
1994 MC ProStar 190 Indmar 275hp EFI, PowerSlot White/Red
Just mounted a shower system in two different boats, controls mounted to the flange in the port ski locker and hoses routed thru the plate in the back of the locker, the shower pump mounted next to the tank to the floor and the switch mounted in the drivers side pod. You may have to install a breaker or fuse for the system, also if you order the system make sure it is for a correct craft for the longer hoses.
