2012 model 230 automatic bilge ???
  • djmekinac
    • Apr 2012
    • 63
    • Canada
    • SAN 220 2007 SAN 210 BYERLY 2012
    The bilge pump is the only(horn?) electrical accessory that is not controlled by the linc system. If you're concerned with water accumulation in your boat, you should leave one battery on with the link system off. With the linc system off, all the electrical components are off and therefore it protects your battery from being drained. You have to activate the bilge switch once you turn off the linc system in order to be in auto mode. If it is running without stopping, try turning it off and on again, I believe the led should be blinking on the bilge switch.
    So there's no toggle switch like previous models but it is a better overall system since the old toggle switch didn't control all of the electrical accessories and you could end up with a defective component that would have drained your battery.
    2012 210 Byerly
    2007 220 SANTE
    2003 Moomba Mobius LSV
    • djmekinac
      • Apr 2012
      • 63
      • Canada
      The horn also works when the link system is off, the toggle switch was replaced by the link system, same function but better managed.
      2012 210 Byerly
      2007 220 SANTE
      • jshack01
        • May 2012
        • 139
        • Louisville, Ky
        • 2020 Super Air Nautique G23 (Gold/Onyx Black) 2017 Super Air Nautique G23 (Indigo Blue/Onyx Black) 2012 230 SANTE (Red/White)
        As mentioned in some of the previous posts just leave the battery on 1 or 2.
        Also, speaking from personal experience from this past weekend, make sure you are NOT standing near the bilge port on the starboard side when your wife turns on the batteries.
        2012 Super Air Nautique 230 Team Edition
        • robertsmcfarland
          • Oct 2004
          • 544
          • Hyco
          • 2014 g23 550
          jshack01, been there, done that ,while boats on lift, bilge port about 24 inches above deck, have soak a few myself.
          2013 G23 super air
          2010 230 super air
          2009 220 super air
          2008 210 super air
          2005 210 super air
          2003 calabria pro air
          • supernatural61
            • Aug 2012
            • 3
            • Phoenix
            • 2012 Super Air Nautique 230
            Follow tgator instructions, I believe he is correct....btw, battery must be on (and you can put it in any position you want).
            • Dinsdale
              • Aug 2010
              • 60
              • British Columbia, Canada
              • 2019 G23
              #21
              2011 Linc1 had the toggle switch, 2012's do not. Leave whichever battery you want on, use your code to lock the Linc2. Bilge will automatically stay on and check for water every few minutes. You do not need to turn it back on. The only things that work with the Linc2 off are the bilge pump and the horn. The blower will not work until it is unlocked.
              2012 Sport Nautique
              2011 Sport Nautique (Sold)
              2000 Malibu Sunsetter LXI (Sold)
              • robertsmcfarland
                • Oct 2004
                • 544
                • Hyco
                • 2014 g23 550
                #22
                on the g23 and I assume on all 2012 you can turn every thing off by hitting the stop pad twice which leaves the bilge on, then hit the bilge pad which turns that off. that's quicker and easier then opening the little door and turning the battery isolator.
                2013 G23 super air
                2010 230 super air
                2009 220 super air
                2008 210 super air
                2005 210 super air
                • Dinsdale
                  • Aug 2010
                  • 60
                  • 2019 G23
                  #23
                  That only works if you've never put your own security code in. If you have put your own code in, you must input it and then push stop. That shuts everything down except bilge pump and horn.
                  2012 Sport Nautique
