I have a 2002 Super Air TE and would like to modify the system so I can individually fill/drain each ballast tank. If anyone has accomplished this, please post your approach, where you mounted your extra switches, etc. Photographs would be appreciated. I do not want to modify the boat any more than I must.
Tags: None
wakemakers tankbuster kit. http://www.wakemakers.com/99-02-naut...t-upgrade.html
You will also need to add another drain and fill pump (if you stick with aerators) and separate the system. It should be pretty easy to do. Call Jason or Spencer at Wakemakers and they can walk you through it.Now
2000 SAN
Previously
1999 Air Nautique
1996 Tige Pre-2000
Yes and No. My boat has a fill/drain pump per tank, but electrically they are all operated simultaneously; one fill switch, one drain switch. Right now, if I want to just fill a specific pump, I simply valve out that fill pump via the manual valve. Its pretty easy, but it does dry run the valved-out pumps. Draining on the other hand, its all or nothing.
