2002 sante steering pulls to port
  • Jim SANTE
    • May 2012
    • 4
    • Shelby, NC
    • 2002 SANTE python
    I just acquired a nicely maintained 2002 SANTE with Python. The prop and rudder appear true and unblemished. However, the boat wants to steer hard to port at every throttle position. Is that a common issue? If not, is there a simple fix? The steering wheel turns easily and the boat turns well, as long as you have a tight grip. At soon as you loosen your grip, she goes to port.
  • RideButter
    • Feb 2011
    • 189
    • Fuquay-Varina, North Carolina, United States
    • 2015 A22 2014 A22 SOLD 2009 210 SOLD 2007 210 SOLD
    Check the tab at the back of the rudder, it is adjustable for how much pressure you want against the rudder.
    [URL="http://www.ridebutter.com"]http://www.ridebutter.com[/URL]
    • Jim SANTE
      • May 2012
      • 4
      • Shelby, NC
      • 2002 SANTE python
      Thanks for advice. How do you adjust it? -Jim
        Loosen the screw that holds the trim tab.
        Move the trim tab to port. It then pushes the main rudder starboard, and corrects a port side pull.
        Tighten the screw for the trim tab.
        • xlair
          • 694
          • Wisconsin
          uh need boat pics!!!
          2001 Pro Air Nautique
          • Jim SANTE
            • May 2012
            • 4
            • Shelby, NC
            • 2002 SANTE python
            Understood. Thanks for your response.
