Originally posted by OKWAKEBDR
View Post
1) More blades in the water = improved holeshot... but less efficient at top speed (lower top end)
2) Pitch is pitch (regardless of blade count). More pitch = worse holeshot and decreased RPM's across the band. Opposite for less pitch.
3) Diameter is diameter. Larger = better holeshot, and will bring down RPM's at speed slightly. Smaller = more efficient (higher top speed).
I cannot see a prop that has 3/4" less pitch running fewer RPM's at speed. The 1/2" larger diameter will offset it a little, but not all the way. I can certainly see the larger diameter, lower pitched, extra-bladed prop coming out of the hole noticeably better though.
Both Delta and Acme will allow you to return a prop for a credit towards another one within a certain grace period (30 days?). Delta can sell at a much reduced price though, as Acme's policy dictates they sell for full retail in order to protect their dealers.
