'02-'06 SAN and prop sizes?
  • core-rider
    • 1351
    • Huntsville, AL
    • 2003 Black SANTE
    So with the talk about newer 210 hulls and prop sizes I got to thinking more about my older hull again. I'm running the 1464 (13.5 x 14.25 .105 cup) right now, and everything I've ever read/seen has told me larger diameter will make more difference than pitch (to a certain point). I'm thinking I can get at least a 14" prop to fit and not cause any issues with gelcoat burn since I don't run more than 4000RPM under normal conditions and that is only for 10-15 minutes to find good water.
    He thought their 1846 (14 x 14.25 .150 cup) would be a good choice as long as the prop didn't get too close to the hull. I think this will keep me within their 3/8" rule as if I remember correctly I measured for a 14.5" and it would only allow for 1/8"-1/4" clearence. I also talked with him about trying some of their new 5 blade props. They didn't have any made yet, but her thought their Gen 2 series had something to offer in the 2406 (13.5 x 14.5 .105 cup). His thinking was the 14" would actually be closer to the clearance of the 14.5" 4 blades because of the blade spacing.
    I guess this all leads me to the main question... Is anyone running a 14 - 14.5" diameter prop on their 2002-2006 hulls? If so what clearance do you have?
    Jason
    All black 2003 SANTE
    -- Southern Fried --
  • core-rider
    • 1351
    • Huntsville, AL
    • 2003 Black SANTE
    Bump... anyone?
    Jason
    • crobi2
      • Dec 2010
      • 337
      • Texas
      • 2000 Super Air Nautique
      Ok, got the 1846.
      On our boat it has 11/32 of clearance which is a little closer than I like but the acceleration is incredible. It's also incredibly smooth with no detectable cavitation even with hard acceleration.
      I had a feeling that a 14" prop would be great and this thing is.
      Big thanks to Greg at Acme for telling me that it would fit, Gary at Delta for fixing me up and Jeff for getting the sponsors!
      Rob
      2000 SAN
