Trying to match my gel coat. It was the light blue that was used in 2003 any ideas what color it is called and where I could get some? Or other options?
Tags: None
Haha looks like HS beat me to it but I was going to send you that same link. Having never seen your boat I think it is either Royal Blue or Steel Blue.
As for matching the color, I assume you are doing some repair work? I don’t think you’ll be able to find the exact color and even if you did I bet your boat has faded to some degree regardless of how meticulously maintained it was so the repaired spots would be darker that the rest of the boat. I have never done any gel coat repair but I know they make kits where they give you the primary colors and you mix and match until you find the right color. I am sure it will take some trial and error to find the right combination of colors but I have heard it’s not too bad. I need to do a few minor repairs on the Silver Cloud deck of my boat and I know White Lakes sells it but I was thinking that I would run into issues with the repair being darker than the rest of the deck so I’m not sure what route I am going to go.Shawn
2012 Blue Metal Flake SAN 230
http://www.spectrumcolor.com/Items.a...CTCRAFT&key=mr
Maybe get a tube of the proper color then a tube of white to lighten it. You can look them up by model.
or if it isn't conspicuous, just live with richer color repair.
