200V w/FCT3 & Z5 Folded Going Under 8' Door
  • sodbuster88
    • Nov 2008
    • 368
    • Clayton, NC
    For anyone wondering if it works without taking the Z5 off the tower...it does..
    Peace..
  • Montana Boat Guy
    Montana Boat Guy
    • Feb 2012
    • 112
    • Rockledge, FL
    Great to see it fits. The only exception would be variations from different trailer manufacturers. Different bunk set ups, tire/wheel sizes, or suspension systems could make boat sit higher than yours. Hope everyone is as lucky as you!
    • Quinner
      • 2246
      • Correct Crafts
      Is your garage door opening 8'H or 7'H? What is most common or considered "standard" here in the midwest is a 7' high opening.
      • sodbuster88
        • Nov 2008
        • 368
        • Clayton, NC
        I've got an 8' door (+/- 1 inch). Trailer is ramlin with 19 inch hitch ball height. I believe the boat sits just a bit higher on this trailer due to hull width. I have about 1.5 to 2.0 inches of clearance with the rig folded down behind the windsheild. Need to have the swivel racks turned in to give more clearance...when they are turned out, they become the constraint and barely fit under 8'. Hope this helps.
        Peace..
