Surf Wake with a 210 with Python
  • andmarthow
    • May 2011
    • 21
    • Starkville, MS
    • 2002 SANTE w/ 8.1L Python 1992 Nautique Excel, Ope
    I have been trying to set up a good surf wake behind my 2002 Super Air TE (python powered), but just can't seem to get right. Can someone please offer a little coaching? Maybe tell me how much ballast you used and where it was placed. Thanks.
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    I posted how I set up my wake a few years ago. I also have an 02 san, just not a python. I have it pretty dialed in. Just do a search on my name and it should come up
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
    • natedog
      • Feb 2011
      • 140
      • New Braunfels, Texas
      • 1996 Super Sport
      put 750lbs on whatever corner side you want to surf and another sack full on the same side seat or floor fill belly to 600 and bow side of surf to 500 bout what i have and is plenty big and clean with just 3-4 people. have the xtra peeps sit on the surf side corner as well
      1996 Super Sport
      • bchesley
        • Feb 2006
        • 1252
        • Tyler, Texas
        I have an 01 python 210 and have the factory ballast full on both sides, a 400 on top of factory ballast on which ever side someone is surfing on and a seat bottom sack 750 in the locker full. I make everyone sit on the side we surf. It works pretty good.
        Brad
        2001 Super Air Nautique
        Python Powered
        100 Amp Alternator
        Dual Batteries
        Many upgrades coming...
        • johnboyy7
          • Oct 2009
          • 409
          • houston
          750 in corner, 400 on gunnel, center tank full, 600 in bow on surf side. usually one one on sun pad, one on seat.
          04 SANTE 210
          89 SPORT
          • lucky7t
            • Mar 2011
            • 1306
            • Oklahoma
            • 2015 SANTE
            While i 100% agree that the setups above make a killer wake you may not need as much. I had an 03 SANTE and filled up the side i surf on, the bow and added two 200lb fat sacs on the seat of the side i surf and it worked great. The wake wasnt gigantic but worked well with either a cwb board and the Inland surfer sweet spot.
            I did the same on my 2007 SANTE and notice a longer wake and worked great. I learned how to maintain the sweet spot and now plan to get bigger bags and make a bigger longer wake.
            Also might check your speed.
            Hope i helped
            Current Correct Craft Boat
            Correct Craft Boats Owned
            • RainDog
              • Jan 2008
              • 64
              • Wauwatosa/Green Lake WI
              • 1962 Classic 2002 SAN -Python Powered-
              I have detailed information how I weighted my former 2002 Python SAN in the ad I listed a few weeks ago. It also shows pictures of the wake at two different speeds. Regarding speeds, paddlewheel Perfect Pass readings at surf speeds will be fairly consistent and repeatable for your boat, but can vary quite a bit with other boats. Meaning, my 10.3 might be 11.0 on your boat.
              http://www.planetnautique.com/vb3/sh...SANTE-for-sale
              Quick answer - 800 port locker, 400 on port observer's seat, belly 3/4 full and 200 in port bow under the seat. Not huge but plenty powerful and fairly long for a 1st gen 210. A few more peeps and it got quite a bit bigger.
              1962 Classic
              2002 Super Air -Python Powered-
              Many more to come....
