Fat Sac setup, 99 Air Nautique
  • wakemeup3460
    • Aug 2011
    • 38
    • Ventura, CA
    • 1977 Challenger jet 1977 Rogers Dragstar, jet dra
    Have a 99 Air Nautique with the following fat sacs and factory ballast:
    2 Fly High Tube Sacs. 370 lbs a piece. 720 lbs total. 62L x 16W x 10H
    2 Fly High Side by Sides, 260 a piece. 520 total, 48L x 12W x 12H
    Factory ballast, 200 each rear corner, 400 total
    Total pounds: 1660
    We played around with them for surfing and didn't get a very good wave. What is the best way to set them up for both surfing and wakeboarding? Obviously, I would be moving them around for each sport.
    Also, I noticed that the swim step screwed up the wave by deflecting water. Do you guys ever remove it for surfing?
    Thanks for your help.
    • Apr 2025
    Never tried removing the swim step, but I have always wondered about it. I got a strong surfable port-side wave (but not terribly clean) with 560 lbs in the rear surf side, about 500 in the belly and about 250 in the nose (surf side). Sometimes I found filling up the non-surf side rear to about 200 helped as well. Starboard side is probably better, but I never really played around with that side.
    Post a picture of your boat.
    • wakemeup3460
      • Aug 2011
      • 38
      • Ventura, CA
      Fat sac setup on 99 Air
      Thanks
      When you say "in the rear" are you talking about in the rear storage compartment or on the floor, in front of the rear seat, and next to the engine cover. I assume "in the belly" means the ski locker. Where exactly do you mean "in the nose"? Are you talking about inside of the bow compartments under the seats or just on the carpeted floor area in the bow?
        • Apr 2025
        In rear I mean in the rear hatch compartment where the factory ballast is. I also had 160 lbs in lead along the gunwhale hidden (pulled rear seat). I would keep that lead (pop bags) on both sides for wakeboarding, and would move it all to 1 side for surfing. In belly means in ski locker. In nose, I meant underneath the seats. I had one of those integrated bow sacs. If you look at my profile, I have an album with pics of most of the setup. I did rip out the tanks though and installed a ballast puppy system. You can also find a surf video I took with that setup if you search under my name.
          • Apr 2025
          http://www.youtube.com/watch?v=wLq4eTfTfOU
          Looks like I had 380-400 sac on the rear seat off center biased to the surf side as well. This was about my 3rd time surfing in this video (taken 2 years ago). Also, I had a fresh air exhaust on the boat, which might affect the surf wake negatively a bit.
          • wakemeup3460
            • Aug 2011
            • 38
            • Ventura, CA
            Thanks Chexi. Not too bad of a wave. Great pics on from your album. I may tackle something like that this winter. Question: If you had to do it over again would you even mess with the 99 and just buy a SAN? With both boats converted is the SAN a lot better in terms of wakeboarding and surfing?
            Did you sell the Python? Awesome boat.
            Thanks again and I don't have any updated pics of my boat. But will try to post something the next time I get it out. Its in a tight storage place right now.
            • Dnovo3
              • May 2012
              • 4
              • NorCal
              • 1999 Sport Nautique 1995 Ski Sanger DXII - SOLD
              Chexi, I just bought a 99 SN and I have a few questions about your ballast. Was it difficult/worth the work removing the factory ballast? Is there anything you would have done differently?
