2012 210 TE Ballast removal
  • austin
    • Jul 2012
    • 21
    • Manassas, VA
    • 2012 Super Air Natique Team Edition
    I plan to remove the rear ballast tanks out of my 2012 210 TE, and replace with 750lb bags. I want to confirm that when I disconnect the ballast level sensor that it will not lock out the ballast from pumping or filling?
    Anyone done this process on a 2012?
  • djmekinac
    • Apr 2012
    • 63
    • Canada
    • SAN 220 2007 SAN 210 BYERLY 2012
    I would put in 1000 if you do not already have the 750, it should work, N3 does that on 210.
    Browse this thread:
    http://www.planetnautique.com/vb3/sh...light=210+surf
    2012 210 Byerly
    2007 220 SANTE
    2003 Moomba Mobius LSV
    • jonfo
      • 385
      • Bellevue, WA
      • 1990 SN 2016 G23
      i agree, go with the 1100, I have a 220 and the 750 only fills it 2/3 of the locker. I had to reinforce the wall between the locker and the engine compartment as well because the bag pushed in on it. just pull the quick disconnect on the ballast pickup on the tank and test it, it will still work.
      -Jon
      16 G23
      07 220 TE
      05 211 TE
      95 SS (210)
      89 SN
