V-drive in Reverse
  • Dmulcay
    • Jul 2012
    • 8
    • Buford, Ga
    • 2005 SV 211
    V-drive in Reverse
    Is reverse a little different than a standard inboard/outboard? I imagine it would be since the an in/out is pulling the boat in a sense and the v-drive is not. Any words of wisdom?
  • shag
    • 2217
    You will notice a little difference.... And the year, depends on the direction it pulls while in reverse.
    • HS
      • Oct 2007
      • 1333
      • Sammamish, WA
      • 2010 SANTE 210 (Sold)
      Yep. The I/O as you mentioned is a lot different because it provides directional thrust whereas a direct drive / v drive works with a shaft driven prop and rudder.
      • SkiTower
        • 2172
        • Clayton, NC
        one word: practice. go practice in the open before you get into a tight situation. Backing up is an inboard's Achille's heel. It can be done but you have to know what you're doing. Good thing is once you figure it out you'll impress everybody with your driving skills. Kinda like when stunt drivers slide sideways into a parking space.
        2007 SV211 SE
        Tow Vehicle 2019 Tundra
        Dealer: www.Whitelake.com
        • migs
          • Aug 2008
          • 703
          • San Mateo, CA
          • SAN 210 TE
          only reverses in one direction, not both like an i/o.
          Migs
          G21 - En route
          SAN 210 TE (Finally)
          06 Sky Supreme V220(previous)
          05 Sanger V210(previous)
          01 MC X1(previous)
          99 Air Warrior(previous)
