Originally posted by 81nautique
View Post
2012 Sport Nautique
2011 Sport Nautique (Sold)
2000 Malibu Sunsetter LXI (Sold)
Originally posted by swc5150 View PostI suppose the 6.0 would be the optimum way to go, budget pending. It's too bad it's a $6,500k (retail) upgrade.
Originally posted by swc5150 View PostI agree. The 200DD is fine with the 5.7, I just wish it pulled fewer rpm's at slalom speed.
If you dont barefoot, then Im sure its fine... but 43mph (unloaded) is pretty marginal if you do.1990 Ski Nautique
NWCT
We popped a new 422 on it, and it lowered the rpm's a little, but also caused a vibration. I don't think that's normal, but regardless, we put the factory prop back on. I'd wait until someone with unlimited funds figures out the perfect mate to the 343.
It's also not underpowered in the slightest at slalom speeds, it just revs at about 4,300 at 34. It takes some getting used to, listening to the motor working that hard at 34, after coming from a 196.'08 196LE (previous)
'07 196LE (previous)
2 - '06 196SE's (previous)
The 422 + Excal combo worked great for years and years on the 196. Theres every bit as much hull clearance on the 200, so that shouldnt be an issue. If the prop vibrated, then it was probably either a damaged prop, or an installation issue.
My underpowered comment was in reference to using the 422 with an Excal boat. Obviously CC propped it down to help with holeshot. Turning lower revs at slalom speeds (due to a taller prop like the 422 vs. the 1868) would have the engine producing less hp at that speed... but not to the point where performance should suffer much. It would also produce a softer pull, and possibly a softer rooster.1990 Ski Nautique
NWCT
Maybe we'll try popping the 422 on again. It's a brand new prop, so it should be in good shape? As Jody mentioned, he's never seen a new CNC prop that was faulty from the factory.'08 196LE (previous)
Originally posted by Dinsdale View PostIn two years of ownership we've never had the rope get caught between the cushions. They fit pretty tight. The pylon does have a little play in it but as soon as there is pressure on it, it's solid as a rock. Try the boat. We absolutely love ours. Added two 450 bags in the back. Wake surf is now amazing for a 20 foot boat. They tie right into the overflow hose so once the tanks are full, they fill. Pretty slick.
Originally posted by High altitude View PostI presume you surf it on the port side due to prop rotation? Have you tried the starboard side as well? Also, do the 450's fit in the storage compartments on either side of the engine? Lastly, a question about the slalom wakes...people have commented about a pretty big pop at 15 off....is that at all speeds? I usually run our course at 28 or 30 mph at 15 off. I would love to transition to a Sport 200 but I don't want to lose out on an occasional slalom run. I currently have a 99 SN with a triple pump system and about 1250 pounds of ballast. It's a real nice surf wake but I can go back to slalom is less than 10 minutes and needless to say that wake is beautiful. Since I spend about 70% of my time surfing now (used to be the opposite with skiing until this year) I wwould like to get something a bit better for surfing with a bit more room. Thanks in advance for any responses! -Marc2012 Sport Nautique
Thanks for the quick reply. This boat really sounds like the "1 boat quiver". It can do it all. I probably need to set up a demo with a dealer and see/feel it for myself. Anything you are not happy with? -Marc
Yeah, I wish the hem wasn't so nicely set up. Excellent visibility, comfortable seat, logical controls, heat ducts. Between my wife and my daughters I never get to driveHull is quite sensitive to weighting so you have to make sure your passengers are spread out evenly. No major complaints.
2012 Sport Nautique
A lot of talk here about the slalom wake on the 200v. How good is this thing for wake boarding or is it still a real compromise. I'm trying to talk my friend who is a die hard BU guy to give it a try. He is comparing the Malbu VTX as he is insisting on staying with a 20 ft boat. He really likes my 200dd but he is a wakeboard only family so no need for a dd. Would he be disappointed in the 200v as a pure wakeboard / wake surf boat?
Trying to be a Nautique supporter but don't want to push him down the wrong road.
Surf smith,
The main wake boarding is done by his son ans my son, both 9. Both are ok, going wake to wake and 180's. So far they are staying away from inverts (not sure I'm ready for that with a 9 year old). Both boys love it and will continue to progress. That was the basis on my question, if they progress to a more hardcore wake boarders, will they be disappointed. I will get my friend in a boat, but hard for the kids to really assess the wakeboard capabilities. Neither of the dads board.
