I'm considering engine options for a G23. Everyone is saying the ZR450 is the only way to go, even though CC puts a 343 in as the base engine. I am currently running a 343 (with an ACME 1235) in my 09 SANTE 230 and it performs just fine. We do not slam the boat with weight, typically just the factory ballast for wakeboarding (which is what we primarily do). I'm told the G23 with no ballast will throw a better wake than a 230 with factory ballast.
Take a look at the attahced chart and tell me if I'm looking at this correctly. I'm looking at boat pounds per HP of each engine. Currently, I'm at 14 with my 230/343 combo. Seems to me a ZR409 in a G23 at 14.5 would do just fine. Is it worth the extra $$$ to get a ZR450 just to go to 13.2?
Another factor is torque, which PCM will not publish. I think they don't publish torque specs because there isn't much gain above the 343. For wakeboarding/surfing, torque is probably a better indicator the HP.
That's for the input!
