Engine oil
  • agouge888
    • May 2012
    • 102
    • Tennessee
    • none
    Engine oil
    At work headed to lunch...Out getting some oil for the 25 hr break in oil change. Didn't get a chance to look at the manual yet, it's at home...what are u guys using as far as weight and brand for oil? Also which filter? I have a 210 with 343 in it. Thanks, agouge
  • swc5150
    • 2240
    • Eau Claire, WI
    • MasterCraft Prostar
    15W 40 oil (Royal Purple is what I use). Motorcraft FL-1A filter
    '08 196LE (previous)
    '07 196LE (previous)
    2 - '06 196SE's (previous)
      No need to use a synthetic oil. Even if you do, do not extend the service interval.
      • swc5150
        • 2240
        • Eau Claire, WI
        True on the intervals DC, but running RP bumps the top end speed up a couple mph. Got that advice from Jody, and it works.
        • agouge888
          • May 2012
          • 102
          • Tennessee
          • none
          Thanks guys. Anybody got a primary fuel filter cross reference number? Gotta change it too. Thanks, agouge
          • Flyerace
            • 39
            I use Pennzoil 15W40 Marine Grade in my '03 Excalibur......Cheapest if you can buy it from an oil distributor, not a marina.
            • lucky7t
              • Mar 2011
              • 1306
              • Oklahoma
              • 2015 SANTE
              I use 15w40 rotella. It's a diesel oil but works great
              Current Correct Craft Boat
              Correct Craft Boats Owned
              • AirTool
                • 4049
                • Katy, Texas
                Its just primarily "marketed" as a diesel oil because of the viscosity. (as most or all of the 15w40s) It is certified by API as an oil for gasoline engines also.
                • Nautiques_NZ
                  • Jul 2010
                  • 65
                  • Hamilton
                  FCC filter? Genuine only to my knowledge RP080026, the small metal inline if fitted is RA080024A pretty sure there is a WIX replacement for this, Or if it is the screw on filter 2012- a Racor S3213
                  • jchamlin
                    • Jun 2004
                    • 171
                    • Charlotte, NC
                    I use the rotella too...something about having a certain additive in there. I'm sure someone will chime in with the name.
                    I have the GT40 and it may be something required for that. I know some folks use Valvoline VR1 but I have trouble finding it locally.
                    2000 Air Nautique
                    • gride
                      • Jun 2007
                      • 1441
                      • War Eagle
                      • 05' 210 team
                      i get confused but something about the rollers in certain engines requires more zinc or something like that. i've always used rotella t and an fl-1a filter.
                      • swc5150
                        • 2240
                        • Eau Claire, WI
                        Older tappet motors require high zinc contents in oil, like the gt-40 for example.
                        • firefighter
                          • Oct 2009
                          • 63
                          • Winter Garden, fla
                          • 2013 ski 200 O/B Team 2012 ski 200 O/Bteam sold 2011 ski 200 O/B team sold 2010 ski 200 O/B team sold 2009 ski 196 2008 ski 196 2007 ski 196 2006 ski 196 2005 ski 196 2004 ski 196 2003 ski 196 2002 ski 196 2001 ski 196 2000 ski 196 1990- 1999 ski 196
                          Go with the rotella. I personally use it and have been for years with out problems.
                          • AirTool
                            • 4049
                            • Katy, Texas
                            What we really need is a thread where people can report an instance where absolutely, positively, without-a-doubt, an engine related / lubrication problem was attributed the brand of an oil.
                            • TRBenj
                              • 1681
                              • NWCT
                              I would love to hear an explanation of exactly how you propose to determine such a thing with absolute certainty.
                              1990 Ski Nautique
                              NWCT
