Alternator belt
  • BStack
    • Apr 2011
    • 46
    • Los Angeles, CA
    • 2000 SAN
    Alternator belt
    Need to replacea busted alternator belt - can I just bring the busted belt into a the local auto supply store?
    Bill
    2000 SAN
  • mdkaggie
    • Apr 2012
    • 16
    • Keller, TX
    Happened to me 2 weeks ago. They are cheap at Nautiqueparts.com. Just order the set so you have an extra main belt also. One bolt on the GT40 and use a prybar to pull the alternator back. One and done don't over tighten. Good Luck.
    • AirTool
      • 4049
      • Katy, Texas
      Is there a number on it that is not PCM? Better to cross it over from the number. Generally, the number indicates the length.
      If it doesn't have a number, better to order from nautiqueparts.com. Then, if you insist, you could have it measured at the parts house with the proper measuring tool.
      I don't recommend measuring a broken belt or worn out belt unless your just putting it on to get home then replace with the proper one.
      • BStack
        • Apr 2011
        • 46
        • Los Angeles, CA
        • 2000 SAN
        The belt reads 7400 GATES XL and has a 11A1015 - is that a PCM number? How would I check?
        • stealth71
          • Jul 2012
          • 10
          • Orlando
          Gates is the manufacturer. They make almost all belts and about the best quality. Your local Napa should be able to get it for you.
          • AirTool
            • 4049
            • Katy, Texas
            7 is the width and 400 is the nominal length. If you were happy with that one, go get another.
            I'm pretty sure 11A1015 is the pcm number. More to follow.
            • stealth71
              • Jul 2012
              • 10
              • Orlando
              Looking at the Gates interchange that 11A1015 is a metric number and crosses to:
              Edit. I missed the 7400 XL.
              http://www.gates.com/part_interchang...cation_id=3286
              Product ID
              87017400
              Part #
              7400
              Product Description
              7400 AUTO V-BELT XL
              UPC
              072053012682
              Category Hierarchy
              Automotive -> Belts -> Automotive XL® - V-Belts
              Product Images
              Product Features
              Application
              Features Advantages Replacement belt for today's most demanding engine drives.
              This variable notched belt tightens on the drive as it gets hot.
              Improved belt performance occurs by reducing tension decay and noise.
              Precise top width and sidewall for proper fit in pulley and quieter belt.
              Meets or exceeds SAE J636C specifications.
              Belt / Sprocket Specifications
              Angle 36
              Effective Length (in) 40
              Effective Length (mm) 1016
              Outside Circumference (in) 40.58
              Outside Circumference (mm) 1031
              Top Width (in) .41
              Top Width (mm) 10
              Product Attributes
              Notched Yes
              Section HC41
              Weight
              Weight (Lbs.) .21
