Hot Water shower question
  • agouge888
    • May 2012
    • 102
    • Tennessee
    • none
    Does anyone on here have a hot water shower on their Nautique? I have a new 210 and had thought about adding one for cool weather riding. Its nice to warm the wetsuts up before putting them on for our second set Any tips on how they hook up, and or how they are plumbed? Is it a chore to do? Thanks,
    agouge888
  • robertsmcfarland
    • Oct 2004
    • 544
    • Hyco
    • 2014 g23 550
    I think on the open loop motors there is no problem, but closed loop the plumbing is going to be a little tricky .
    2013 G23 super air
    2010 230 super air
    2009 220 super air
    2008 210 super air
    2005 210 super air
    2003 calabria pro air
    • swankster
      • Aug 2010
      • 1052
      • DFW, TX
      If you don't want to control the temp or the pressure the easiest way is to remove a drain petcock, replace it with a hose nipple and attach a good temp rated hose and sprayer. You can splice in a ball value in the line as an on/off device.
      2010 SANTE 230 343 (280hrs)
      • Laketexoma
        • Dec 2004
        • 463
        • Lake Texoma (Texas side)
        • 2023 G23
        I put it on our 230 with the 390hp(closed loop). It was not hard took about 3hrs. got my shower from dim. I hardly use it. I think its been on 3 times in 5 years. It does get very hot if you just have the hot water on.
        texoma
        2016 G23 H6
        2014 G23 550
        2013 G23 450 (Great boat)
        2000 SAN ( Loved that boat)
        • magilla
          • Aug 2012
          • 2
          • Louisville, OH
          • 2008 SV-211
          yep. I have one installed on my 2008 SV-211. Motor is located in rear of the starboard storage compartment. Shower head pulls through a drilled opening through the transom. Water temp is fully adjustable from lake temp to scalding hot, water pressure is execllent. I will admit to having it professionally installed as the thought of drilling a hole in the fiberglass transom made me more than a little nervous.
          • RexB
            • Oct 2009
            • 74
            • Sacramento, CA
            Be careful. The water that comes directly off the motor is hot enough to scald. That's why so few boats come with hot showers any more. When they did, like my old Centurion, they almost always had a mixing valve to add lake water to adjust the temp. That said, just add the mixing valve and go for it. it's pretty sweet on a cold day.
            2009 211 Crossover; Triple White
            "I used to be disgusted; now I try to be amused...."
            E. Costello, 1979.
            • Daryl
              • 133
              • Brandon, Manitoba, Canada
              • 2004 Ski Nautique 206 1990 Ski Nautique
              skied yesterday (I'm in Canada).... Shower came in very handy! I mix the hot and cold together through a simple brass garden hose "Y" valve.
              Heater in the boat is good - BUT - hot water is the only way to really take the "chill" out of a late fall (or early spring) set.
              Current Boat ==> 2004 Ski Nautique 206, LOVE IT!
              Former Boat ==> 1990 Ski Nautique, PCM351
              • AirTool
                • 4049
                • Katy, Texas
                There are now PEX fittings with a built in and adjustable temperature control valves. I wonder that would work? I'd have to think about the pressure drop. It might be too much.
                If you are blending? do you need two pumps? or is the pump strong enough to suck from two suction lines?
                These are available in various brands and connectors.
                http://www.pexuniverse.com/honeywell-mixing-valves
                • Nordicron
                  • Sep 2009
                  • 557
                  • Madison, WI
                  If you just hook a hose and sprayer up to the manifold do you need a pump?
                  • ClemsonDave
                    • Oct 2004
                    • 659
                    • Glen Allen, VA
                    • Ski Nautique 200
                    Funny this came up. I just purchased a shower kit (Heater Craft 101SC). The buyer of this year's boat would like one installed. I'll probably work on it next week.
                    Promo Team member
                    1999 196
                    2010 200 Team 2010 200 Team
                    2011 200 Team 2011 200 Team
                    2012 200 Team - 2012 200 Team
                    2013 200 Team - 2013 200 Team
                    2014 200 Team - 2014 200 Team
                    2015 200 Team - on the way
                    • AirTool
                      • 4049
                      • Katy, Texas
                      Probably. (Unless its purely for hot water to dribble on you and warm you up. Fan any kind of rinsing effect, a pump would be needed.)
                      The shower kits come with a pump...but usually not shown in the pics. Showing the pump would probably scare off the average customer.
                      BUT, I'm not sure where the pump mounts....after the mixing valve?
                      Here is the kit Dave referenced.
                      http://www.heatercraft.com/101-sc-co...er-system-kit/
