Problem: Backing Trailier up too steep of driveway. Solution?
  • Chexi
    • Apr 2025
    • 2119
    • Austin
    • 2000 SAN
    Other than buying a different house, is there any way to back up an inboard boat trailer on a driveway that is just a bit too steep (prop guard hits)? Are there wheel ramps made for this to lessen the incline a bit (or more correctly stated, to get the wheels starting to incline earlier)? I found a great house with a nice garage for the boat, all near a private launch for a subdivision, but the driveway is a bit too steep to back up (and driving forward and turning around at the top are not possible).
    Now
    2000 SAN
    Previously
    1999 Air Nautique
    1996 Tige Pre-2000
  • SkiTundra
    • Jul 2008
    • 513
    I've seen a few mod'd trailers with basically a wheely bar mounted to the back. Do you have a rod or custom shop nearby? Is the problem a gutter? How about some steel plates to put over it?
    • Laketexoma
      • Dec 2004
      • 463
      • Lake Texoma (Texas side)
      • 2023 G23
      I had 2 wheels of both sides of my prop guard. They were like high strength caster wheels inline. They were 6" and helped alot with mine dragging. Not sure how much weight you will put on them.
      2016 G23 H6
      2014 G23 550
      2013 G23 450 (Great boat)
      2000 SAN ( Loved that boat)
      • TX-Foilhead
        • Mar 2009
        • 351
        • Kingsland TX
        Might be that little foreign SUV your trying to do it with, get a diesel.
        Magnum out on 620 ought to be able to fix you up, Spillar on S Congress could do it if your still downtown.
        • chris196
          • Mar 2007
          • 223
          Look at this thread:
          http://www.planetnautique.com/vb3/sh...ailer-1-2-quot
          there is another thread where I talk about it in more detail, but the pictures got lost when the website moved to newer software.
          there are somethings you can do. It's much easier with the boat off the trailer and I had that luxury when I installed the lift kit.
          • Chexi
            • Apr 2025
            • 2119
            • Austin
            • 2000 SAN
            Don, while I definitely want to upgrade to a diesel, I don't think that would fix this problem. The angle of the driveway is what it is. It's not that the truck can't push the trailer up, it's that the prop cage hits the driveway, and I don't want to scrape it or the driveway up.
            I'm back in Dallas now, for a while.
            Now
            2000 SAN
            Previously
            1999 Air Nautique
            1996 Tige Pre-2000
            • Nautiquehunter
              • Jun 2008
              • 2080
              Get a adjustable hitch mount as you lower the front the back will go up.
              Something similar to this.
              • sstexan
                • Jun 2006
                • 230
                • 1999 Super Sport GT40, NDT 2007 236 Team
                If the lip of the driveway is the issue these things work great. They are pricey but worth it.
                http://www.griotsgarage.com/product/...ortby=ourPicks
                • Chexi
                  • Apr 2025
                  • 2119
                  • Austin
                  • 2000 SAN
                  Thanks all. Lots of great options. The Great PN Brain once again saves the day!
                  Now
                  2000 SAN
                  Previously
                  1999 Air Nautique
                  1996 Tige Pre-2000
                  • TwinTip
                    • May 2004
                    • 294
                    On top of the prop guard wheels/casters or a lower hitch ball to drop the trailer tongue and raise the prop guard, you could also try to get some wooden boards that you place behind each of the trailer wheels, or side, that you need to raise as you are backing into your driveway or garage. You may also need to do the inverse to get the trailer out or you will probably end up scratching the driveway or trailer on your way out. If you need to put multiple boards together to gain more height or clearance on the driveway, you can cut the front at an angle on the lower board, then add the next board with a cut at an angle and placed a little further back, and so on, so that the boards do not become a step but rather a gradual ramp that you drive onto.
                    Hope this helps.
                    • H2O
                      • Jul 2006
                      • 247
                      California Trailer Works (Sacramento) sells prop cage roller kits.
                        • 2908
                        If it has torsion bar suspension you can rotate the swingarms to raise the trailer, I just raised mine 1". It does much better now, don't even notice the difference from a looks perspective. If it has leafs you can add blocks between the leaf and the axle.
                        • bsb4fsu
                          • Nov 2010
                          • 333
                          • East Tennessee
                          • 2021 G23
                          If the issue is at the bottom of the driveway near the street, sometimes it helps if you can angle the trailer at the driveway (e.i. trailer at 45 degree angle to driveway) rather than hitting the driveway straight on.
                          2021 G23 450 - Current
                          2019 G23 450 - Sold
                          2018 G23 450 - Sold
                          2017 G23 450 - Sold
                          2016 G23 450 - Sold
                          2014 G23 550 - Sold
                          2013 G23 450 - Sold
                          2012 210 - Sold
                          2012 200 Mapple - Sold
                          2011 230 - Sold
                          • Chexi
                            • Apr 2025
                            • 2119
                            • Austin
                            • 2000 SAN
                            Thank you. I tried coming at it at an angle, but no luck. It really is just a bit too steep of a driveway with my trailer is it is currently constructed.
                            Now
                            2000 SAN
                            Previously
                            1999 Air Nautique
                            1996 Tige Pre-2000
                            • osukellen
                              • Jul 2009
                              • 50
                              • Edmond, OK
                              • 1994 Ski Nautique Open Bow
                              Used floor jack wheels, welded them to the prop cage. I had the exact same problem. Works great.
