Hot water shower install on a 200
  • ClemsonDave
    • Oct 2004
    • 659
    • Glen Allen, VA
    • Ski Nautique 200
    The new owner wants a hot water shower installed on this year's 200. Since I'll be skiing behind it this winter, I'm happy to do it! Thought I would take some pictures of my progress. Comments are welcome.
    The kit is the HeaterCraft 101
    First, I chose a spot for the controls, hose and shower head.
    Next, used an existing plug for the cold water right at the water pump.
    Found a plug on the block for the hot water. Close to the water pump on the passenger side. Behind the cat and next to a spark plug.
    I decided to mount the pump under the board that goes from the motor box to the back of the boat. Just getting the motor box off was a chore. Had to lift each side, remove the lifting rings, lift the other side, remove those lifting rings, then it will come off.
    I drilled holes for the faucet.
    Took apart the faucet. Drilled a couple holes. Screwed that plate to the board.
    Screwed the faucet back to the plate.
    Done for a while. I'll finish later. One of my biggest complaints with this shower is that the temperature fluctuates a ton. So, I've ordered a tempering valve and will be installing it in-line. That should keep the temp within a few degrees. I also plan on mounting the on/off switch on the faucet.
    Promo Team member
    1999 196
    2010 200 Team 2010 200 Team
    2011 200 Team 2011 200 Team
    2012 200 Team - 2012 200 Team
    2013 200 Team - 2013 200 Team
    2014 200 Team - 2014 200 Team
    2015 200 Team - on the way
  • Nordicron
    • Sep 2009
    • 557
    • Madison, WI
    I put a home made version in my san210 and also found that the temp verys a lot! If I adjust to a steady stream I can get it very nice but stop the flow and wait a minute then it's scalding hot for a bit but goes back to normal temp after about 10secs.
